Microvellum Foundation Library Release Notes | Build 24.0119
Additions:
  1. Added additional King Slide Ball Bearing Slides:
    1. King Slide 3J89
    2. King Slide 3M89
    3. King Slide 3J01
    4. King Slide 3M01
    5. King Slide 3J52
    6. King Slide 3M52G
  1. Added King Slide SIMLEAD Wood Drawer System Bottom-Mount Slides:
    1. King Slide 1X97 (Frameless)
    2. King Slide 1X97F (Face Frame)
  1. Added the ability for all cabinet doors to have up to eight hinges & plates (up from five). Added three new global variables:
    1. “Height To Add Sixth Hinge”
    2. “Height To Add Seventh Hinge”
    3. “Height To Add Eighth Hinge”
  1. Added Harn Impaz Drawer System (no graphics available).
  1. Added “Fixed Shelves with Dividers” mail slot interior component.
  1. Toe Kicks can now machine “up” into cabinet bottom, including Dado. Added global variable "Construction Method Toe Kick Top" to control desired machining method.
  2.
  3. Added a new global variable "Default Inner Drawer Setback". This has been linked to the inner drawer subassemblies and the inner drawers in the 1/2/3 Drawer cabinets. This can be used to push back the inner drawers a specified distance while also reducing the depth of the inner drawers.
  1. Added 3D Diagonal Line for drawer fronts (like 3D Door Swing).
  1. Added the ITEMNUMBER system prompt to all products. MV populates this special prompt with the product’s item number and can be used in various ways such as 2D drawing tokens.
  1. Added new data structure (tokens) to wood drawer subassembly for bottom mounted runners.
  1. Added “Division Quantity” prompt to most all cabinet products that could potentially have an interior component with divisions. This gives division quantity control from the parent product without having to drill into the component subassembly.
  1. Added “Drill Locator Hole” to the list of hinge machining options.
  1. Added global variable “Use Rail Notch” for better control over all rail notches at intersecting divisions.
  1. Added Special Product System Prompts to clipboard (only available in new install).
  1. Added the help text “Top” to all Bay 1 Options prompts tabs in all Vertical Designer cabinets.
  1. Added Confirmat Screws as an option to Screws table.
  1. Added extra tokens for machining dowels/screws from the division into the back and front top rails. This will eliminate the extra horizontal boring previously on the top edge of the divisions.
  1. Added hinge boring locations to Door and Drawer Front Fabrication Report.
If you have a custom Door and Drawer Front Fabrication Report, it is recommended that you unselect it during the Library update.
  1. Open Corner End Cabinets - A Front Corner Square option has been added.
  1. Added “Shoe Shelf” insert as a standard cabinet insert (from the Closet expansion).
Modifications:
  1. Modified the AutoCAD template drawing files (DWT). All layer colors are now Index Colors (no longer using True Colors). This should alleviate issues when printing all layers in black.
  1. Removed obsolete global variables: “RailWidth” and “MidRailCenterHeight” .
Resolutions General:
  1. Blum Tandembox Antaro, Blum Tandembox Intivo, Grass Nova Pro Deluxe, & Nova Pro Scala – The Back Over Bottom feature will now function as expected.
  1. Wood Drawers - Undermount Holes will now move with Back On Bottom option.
  1. 2D “Finished End Text” will now appear regardless if "Display Product Description" is on.
  1. Base Door Drawer Blind Corner – Resolved a notch machining issue with the Front Stretcher.
  1. Blum Movento Drawer Systems will now display the correct locking device hardware on reports.
  1. Resolved an issue with Strip Lighting Insert. Now using Dado token instead of the ASSOCPolyline token to resolve periodic issues with incorrect rout direction.
  1. Resolved issues with Extruded Toe Kick Base. Parts and their locations will now be correct at radius conditions.
  1. 2 Door cabinets with locks will now respond correctly to the number of divisions inside the cabinet. No divisions or “even” number of divisions will automatically prompt a secondary lock (i.e. elbow catch). Odd number of divisions will cause two locks on each door to lock to the center division.
  1. Resolved Lock issue within Base/Tall/Upper 3 Door cabinets.
  1. Resolved issue with Global “Drawer Stretcher” set to “Locked Drawers” not activating the stretchers in locked cabinets.
  1. Blum LEGRABOX Inner Drawer hardware - added formulas to the front brackets and the front rail so the parts will not be drawn when using a timber front.
  1. Updated the Buyout Report:
    1. The Buyout Report filter has been fixed to filter only buyout Type 4 materials. Buyout Report Style 1 will no longer show products with no buyout part materials.
    2. Buyout Report will now show W x H x D of buyout drawers.
If you have a custom Buyout Report, it is recommended that you unselect it during the library update.
  1. Hettich Arcitech will now use the template hardware kit materials and not create project level hardware materials.
  1. Resolved issue with Richelieu Axial Drawer gallery rail machining.
  1. Upper Sloped Top product - Resolved material reference issues.
  1. Hanging Rail subassembly will now chamfer at rear when cabinet is set to chamfer.
  1. Hettich Avantech Drawer – corrected an issue with the finish color misspelling.
  1. Blum METABOX Inner Drawers– Resolved an issue with the Drawer Spacer option.
  1. Resolved an Adjust Shelf issue with Distance to Shelf Hole Front when using Shelf Edge option.
  1. Resolved an Adjust Shelf issue that would occur when using rear notch and fixing hole/slot machining.
  1. Shelf pin hardware quantity now correct when wide span shelves triggers the rear holes on the back.
  1. Resolved several issues with Internal Drawers with Faces subassembly.
  1. Resolved an issue with Crown Molding option. The option will no longer default with the rear crown “on”.
  1. Resolved several issues with Wall Oven appliance product/subassembly.
  1. Resolved 2D elevation issue with the Dishwasher appliance.
  1. Divisions internal insert will now only notch for top rails when it is appropriate to do so.
  1. Resolved an issue with Horizontal Designer products when using the Top Drawer option inside bays. Opening Heights now correct for inside components below the drawer.
  1. Resolved an issue occurring with Open Corner End Cabinets when the back has a different material thickness than side.
Additions/Resolutions Face Frame Cabinetry:
  1. Resolved issue with Lift-Up Door hardware when used in a face frame opening.
  1. Added Lift Up Door Cabinet FF.
  1. Resolved an issue with Base Applied Back Panel FF. Door Style changes will now pass down to nested door subassemblies.
  1. Resolved an issue with Drawer Front Calculator in Split Top Drawer FF cabinets.
  1. Added rounding functions to face frame subassemblies at Angled cabinets to prevent long decimal number dimensions when drawing in 2D Imperial.
  1. Face Frame Peninsula Cabinets – 2D Frame Drawings now supported.
Additions/Resolutions Closet/Wardrobe:
  1. Strip lighting option will now break into two when hutch option is selected.
  1. Closet Corner Cabinet – Shelves will now adjust correctly in depth when changing the “Left/Right inset” variable.
  1. Closet Corner Parts – Resolved issue with pie cutout parts not deducting the same amount for edge banding than the regular straight closet parts.
  1. The dado for the toe kick has been updated to use the "Dado_Small_Part_Notch_Distance_To_Edge" when it’s under the "G!Dado_Small_Part_Threshold".
