The following release notes apply to Microvellum Foundation Library build 24.1025.
Additions
- Added new global variable “Remove Stop Dado On Bottom Edge” for wood drawer boxes. Check this option to run the dado through at the bottom of the sub front and back. This is recommended when the sub parts sit on top of the bottom panel and are too small for a stop dado at both the top and bottom.
- Added features to the Strip Lighting insert.
- The light moves and rotates with sloped shelf angle.
- Added an option for wire cutouts in side panels, end hole route, and wiring grooves to wall for wire.
- Added the Light Valance option.
- Added Hafele 833.72.840 Surface Mounted and Hafele 833.72.840 Recessed.
- Added features to the MDF Profile Doors.
- For grooved panels, added an option to make the grooves equally spaced.
- Added columns to the Lookup Tables to control routes you want to follow the corner routes. If the offset is greater than the radius, it will be square.
- Added new Panel Insert option. Added 6 new columns to D!LookUpTableInternalProfile to control panel insert. Added a material pointer MDF Door Panel Insert.
- Added new global variable “Construction Method Shelf Edge” so shelf edge construction can be unique and different from “Default Construction Method”.
- Added product depth label to the 2D Instructions subassembly.
- Added two Door Wizard variables to restore the “Flat Panel Rabbet” feature in 5-piece doors:
- Flat Panel Rabbet
- Flat Panel Rabbet Width Gap
- Added new global variable “Back Floor Scribe” and linked to all cabinet thick backs. It will activate when the “Extend Back to Floor” is used and a value is entered in “Back Floor Scribe”.
- Numerous changes and adds for 2D elevation views:
- Added four new global variables for better control over the 2D elevation of “Width/Height/Depth” and “Elevation Caption” text. Old global variables “ElvWHD" and "ElvCaption” have been moved to the Legacy category, as they are no longer referenced.
- New variables added to the global and "2D Instructions" subassembly:
- "Elevation WHD"
- "Elevation WHD Offset"
- "Elevation Caption"
- "Elevation Caption Offset"
- The product prompt “ElvWHD” was renamed to “Elevation WHD” in all products.
- Two new drawing tokens were added to the 2D Elv View Instructions subassembly for the Width x Height x Depth and one for a caption.
- Updated all products and changed the prompt “ElvProductDescription” to “Elevation_Product_Description”.
- Global variable “ElvProductDescription” is now hidden.
- Added “Elevation Product Description” and “Elevation Product Description Offset” prompts to the 2D Instructions subassembly. Now, using a DRAWTEXT token for the elevation product description instead of the system prompts.
- Global variables added:
- "Elevation Product Description"
- "Elevation Product Description Offset"
- Added the ability for all drawers to have their attachment screws included in hardware reports. With this, added greater control to specify which type of drawer attachment screws needed for system (euro) screws vs wood screws.
- Added two variables to the Hardware Wizard:
- "Default Drawer System Screw"
- "Default Drawer Wood Screw"
- Added a column to the "H!LookUpTableScrews" for the face panel screw depth.
- Added new hardware "Screw 12mmx3.5mm".
- Linked the Bottom Hole Dia, Bottom Hole Depth, Back Hole Dia, Back Hole Depth, Slide Hole Dia and "Slide Hole Depth" prompts in all drawer subassemblies to the "H!LookUpTableScrews".
- Added new prompts to all drawer subassemblies to control desired screws:
- "Slide Screw Type"
- "Bottom Fixing Screw Type"
- "Back Fixing Screw Type"
- "Slide Hole Dia"
- "Slide Hole Depth"
- All SLIDE tokens in drawers have been updated so they now tally up the number of screws used when a work order is processed.
- With these changes, multiple existing global variables will no longer be used, and can be moved to “Legacy” (unless you have custom drawer subassemblies):
- "Dwr Slide Bore Depth"
- "Dwr Slide Bore Dia"
- "Drawer Back Hole Diameter"
- "Drawer Back Hole Depth"
- "Drawer Bottom Hole Diameter"
- "Drawer Bottom Hole Depth"
- "Drawer Spot Hole Diameter"
- "Drawer Spot Hole Depth"
- Added the “Vent Route” subassembly to Cabinet Modifiers category. This contains options for vertical or horizontal cuts to be added to Left, Right, Top, Bottom, Front, Back of any cabinet. You can also specify the route from the inside or outside.
- Added new global variable “Dowel Drill Through Backs” to have the drilling into the back from associative parts drill from the opposite side and drill all the way through the back to keep all machining on one face.
- Added selection icon for the Universal Hardware Insert subassembly. Also changed the hardware selections from a combo-box to a “control type 9” which allows users to select any piece of hardware.
- Added “Drop Down Door Stay” variable to the Hardware Wizard.
- Added five new Salice Progressa Undermount Slides (3D graphics coming at a later date)
- Salice Progressa Smove
- Salice Progressa+ Smove
- Salice Progressa+ Push to Open
- Salice Progressa+ Shelf Smove
- Salice Progressa+ Shelf Push to Open
- Added Salice PACTA Drop Down Door Hinge System
- Salice PACTA Flap System White
- Salice PACTA Flap System Glossy White
- Salice PACTA Flap System Stainless Steel
- Salice PACTA Flap System Grey
- Salice PACTA Flap System Champagne
- Salice PACTA Flap System Satin Metal Black
- Salice PACTA Flap System Glossy Metal Black
- Added the Kessebohmer CONERO Pull Out System Hardware Range:
- Kessebohmer Conero 72H Trouser Hanger Pull Out
- Kessebohmer Conero 72H Internal Pull Out
- Kessebohmer Conero 168H Internal Pull Out
- Kessebohmer Conero 72H Laundry Pull Out
- Kessebohmer Conero 72H Trouser Hanger And Laundry Pull Out
- Kessebohmer Conero 72H Comfort Tray Pull Out
- Kessebohmer Conero Belt and Tie Rack Pull Out
- Kessebohmer Conero Clothes Lift
- Kessebohmer Cornero Clothes Lift TOP
- Replaced all Blum Hinges and Hinge Plates with “simplified” reduced size CAD files for better AutoCAD performance in 3D.
Resolutions General
- Resolved an issue with Return Fillers on the right side of cabinets. Part origin now correct.
- Resolved an issue with Any Angled Shelf Fixed. Dummy parts are now set to a “negative” material to prevent being added to a work order.
- Resolved a construction hole machining issue that would occur cabinets used notched toe kick and applied backs.
- Resolved an issue with adj shelf hitting blind panel in Tall Open Blind Corner cabinet.
- Resolved an issue with missing “Fixed Panel” option for cabinet Face Options. It was missing from the v24.0823 update.
- When using the global variable “Drawer Box Fixed Location”, the Drawer Bottom Gap will now adjust when entering a positive value for “Bottom Reveal”.
- Resolved a location issue with Blind Corner Hinge Plates.
- Resolved missing machining for the following Fixed Panel Fasteners:
- SH 325 Zero Side Mount Fixed Panel
- Keku AS Push-In Fitting Fixed Panel
- Keku EH Suspension Fitting Left Fixed Panel
- Keku EH Suspension Fitting Right Fixed Panel
- Keku EHS Suspension Fitting Left Fixed Panel
- Keku EHS Suspension Fitting Right Fixed Panel
- Resolved #NAME? errors inside certain Upper Cabinets that affected some prompt values’ formulas.
- Resolved an issue with Secondary Locks (such as elbow catch) appearing in the wrong location when used with a cabinet valance.
- Resolved an issue with Door Drawer blind cabinets that prevented the top-drawer selection prompts from appearing when selecting a wood drawer.
- Resolved an issue with Double Door Tall cabinets where the horizontal door gap was looking at "G!Door_Gap" instead of "G!Horizontal_Door_Gap".
- Added a missing 2D section height dimension token in Solid Wood Doors.
- Resolved an issue with ADA Sink Angled Frame product. Left/Right hand sides with different thicknesses will no longer lose machining.
- Resolved an issue with "Component Door Drawer" subassembly when the global “Door Drawer Stretcher” was set to “none”.
- Resolved an issue with Hafele Alto Slim drawer system. Will no longer be set to “Convert to Inner Drawer” by default.
- Removed the Hardware Wizard variable “KD_Cams”, as it was not being used.
- Resolved reported issues with the Blum REVEGO and HAWA Concepta III pocket slide-in door systems that were discovered by beta testers.
- Resolved an issue with 2+ bay designer cabinets with haunched face frame and radius left/right sides. The haunch machining will now align with the mid stiles.
- Face Frame report will now include face frames from the Face Frame Only product category.
Additions/Resolutions Office Furniture
- Resolved issue with Office Cabinet products involving finished tops & bottoms when using thick backs and Dado/Screw construction. Screw holes will no longer appear at captured backs.
- Office Cabinet products’ Toe Kick parts will now reference "G!Dado_Small_Part_Notch_Distance_To_Edge" and "G!Construction_Method_Toe_Kick_Top".
