The following release notes apply to Microvellum Foundation Library build 24.1127.
Additions
- Added a new Soffit product to the Upper Cabinet Accessories category.
- Added the Top Filler (Ceiling Scribe) option to Upper and Tall cabinets. (Corner Cabinets will be available in the future)
- Added the Blum AVENTOS HF top, HS top, and HL top lift-up systems.
- Added the Hafele Free Flap 1.7 and 3.15 lift-up systems.
- Added the Salice 120 deg hinges Series 200.
- Added four Salice Futura Drawer Slides:
- Salice Futura Smove 7555
- Salice Futura Smove 7955
- Salice Futura Push 7557
- Salice Futura Self-Closing 755
- For MDF Profile Doors with Lites, it is now possible to add up to 3 routes for the glass rebate. This can be achieved by adding a pipe delimited list in the Glass Rebate Tool Name (COL60) and the Glass Rebate Offset (COL62).
- Added a handle to the Integrated Dishwasher product.
- Added the Gollinucci 571 Metal Line and Gollinucci 580 Evo Line bins (Metric only).
Modifications
- Changed the machine point for the Finished Face right door. Now have 3M for the left door and 1 for the right door to better accommodate P2P machines.
- Changing the quantity of drawers in Drawer Bank cabinets will now rename the product to match.
- Adjustable Shelf Standards now using the global “Shelf Standard Tool” instead of “Small Pocket Tool”.
- Removed the global variables “Lock From Bottom Upper” and "Lock From Top Base” as they are no longer used.
Resolutions General
- Resolved an issue with shaped shelf and rear modification notch machining not being on the same face as the adj shelf slot machining.
- Resolved an issue with adj shelf slot machining not aligning with shelf studs when using a shaped shelf L/R.
- Resolved a machining issue with the Blum Aventos HK Top Chipboard. Holes for the front should now be located correctly.
- Resolved an issue with the Toe Kick Assembly Box. Left sleeper will now be in correct location when adding a left cabinet filler.
- Resolved an issue with the 2D Elevation Oblique view of Solid Wood 5pc Doors.
- Resolved an issue with the Vertical Splitter subassembly. The Shelf Edge Face Mounted Lip Down feature should now function as expected.
- Resolved two issues within Base Spacer Corner Drawers products:
- Changing to “M” drawer height will now provide the correct drilling locations.
- Added the missing “Add Lock Second Drawer Front” prompt.
- Resolved several reported issues with the Blum REVEGO system.
- Resolved an issue with Transition Angle Cabinets. Tops and Bottoms will now be flush with end panels and automatically adjust to the correct cut size when using thick edgebanding.
- Added a 2D elevation token for the Aluminum Handle option. This token should appear for both top mount and face mounted handles.
- Resolved an issue with Base 1 Door Sink w/ False Front that would occur when using the Fixed Panel option.
- Resolved an issue with the Blum Tandembox Antaro. Back drilling should now correctly adjust when changing the bottom thickness.
- Resolved a machining issue with Master Angled Ends Cabinet.
- Resolved an issue with Nailer machining. Setting to “None” will now prevent dowels from appearing at Finished Ends.
- Resolved an issue with the Rear Modification options of Horizontal Designer Cabinets. Notches should now only affect the parts in each appropriate bay.
- Resolved a dimensioning issue with Face Frame drawing tokens when used with Horizontal Designer Cabinets.
- Resolved an issue when using frameless hinge plates in a face frame cabinet. The global “Hinge Plate Offset From Front” will be referenced when the plate hardware item is not using the “@” symbol.
