Microvellum Foundation Library Release Notes | Build 26.0112
The following release notes apply to the Microvellum Foundation Library build 26.0112.
Additions
  1. In accordance with Microvellum's new subscription changes, all Face Frame Expansion products and subassemblies, as well as the Range Hood Master product have been added to the full library install and library update zips (now included with base Foundation Library).
  1. Added a new Open Display Shelf product.
  1. Added the Top Scribe Return Filler product to the Upper Cabinet Accessories category.
  1. Added the option to have a 3rd door in the Component Sliding Door subassembly.
  1. Added the Shoe Fence subassembly option in the Shoe Shelf subassembly. This can be a nested subassembly. Current selection options:
    1. Kessebohmer CONERO
    2. Hafele TAG
  1. Added Rails Top and Rails Bottom options to the Extruded Soffit product.
  1. Added RPC 374 Institutional Hinges.
  1. Added the FIT SlimFIT drawer system to the options for the NZ region.
  1. Added the OVVO PD20 to the Invisible Fasteners options.
  1. Added control in the Hardware Wizard for Default Inner Drawer and Default Inner Wood Drawer Slide selections.
  1. Added option to toggle between Wood Spacers and Spacer Hardware in the Hardware Wizard.  Also added Wood Spacer Height to the Hardware Wizard.
  1. Added the Ninka One2Five subassemblies to the Waste Bin Pullout options.  This system can use multiple runner brands so there have been 3 options added:
    1. Ninka ONE2FIVE Blum TANDEMBOX Antaro
    2. Ninka ONE2FIVE Matrix Box S
    3. Ninka ONE2FIVE Grass Nova Pro Scala
  1. Added the Hafele Slido Fold61 25A/50A hardware to the options when Folding Doors is selected for Face Options.
  1. Added global checkbox to Show 2D Drawing Options.  This will turn on the 2D drawing tab in products if checked.
  1. Added “Shadow Line Orientation” prompt in Tall Oven cabinets.  This is to resolve issue when "Shadow Line Finger Pull" is selected in these products.
  1. Added Blum Legrabox Drawer Kit N 550mm 40kg and Blum Legrabox Drawer Kit M 550mm 40kg to the Hardware file.  Also added the Blum Legrabox Side N 550mm Left/Right drawings.
  1. Added drawer slide graphics for the Finista Edge drawer system.
  1. Added the "Flatshot" subassembly and "Flatshot Token" prompt to all Extruded products.
  1. Added and updated multiple 2D drawing tokens.
  1. Added the new Extruded Bench product to the Extruded Fixture options.  This product is currently in Beta and will be improved over time with feedback.
  1. Resolved an issue with Hafele Matrix Box Slim where the rear bracket holes were not correct for the 128mm height.
  1. Resolved an issue with Hardware Array machining on the bottom edge of the Division in the Component Pocket Door subassembly.
  1. Resolved an issue with part layer names in the Extruded Soffit product.  All parts in all subassemblies used are now consistent.
  1. Modified the Hafele Alto Slim drawer system.  The 64mm height has been removed and the 167mm graphics and hardware items have been added.
  1. Resolved an issue with Blum Merivobox where the Cutout Back parts were not sized or placed correctly when "Rear Cutout" and "Rear Cutout Use Metal Sides" were selected.
  1. Resolved an issue with Hawa CONCEPTA 3 where internal cabinet parts were not sizing correctly.
  1. Resolved an issue with Wood Drawer Box depth when Richelieu 818 or 828 drawer slide is selected.  The drawer depth should be 10mm less than drawer slide nominal length for all drawers using the 818 and for all drawers, except the 270mm, for the 828.
  1. Resolved an issue Applied Panel when using MV Profile Door Applied Panel Type and selecting "Applied Panel Ends to Floor" and "Increase Applied Ends Bottom Rail At Floor" in the subassembly prompts. This is now controlled in the Applied Panel subassembly and flows to the nested MV Profile Door subassembly properly.
  1. Resolved an issue in Blind Corner products when using both "Shadow Line Finger Pull" and "Use Blind Corner Hinge". Parts now machine correctly for this scenario.
  1. Resolved an issue with Drawer Spacers not appearing in all designer and double door products.
  1. Resolved an issue in Master Die Wall where dado machining was not accounting for Toe Kick Inset value and extending too far.
  1. Resolved an issue when Shelf Support Fixing Options was set to slot.  Both sides of the shelf now properly align with the shelf pin holes.
  1. Resolved an issue with 2D plan dimensions in corner cabinets not linked to the global Plan Width Base Point.  This is now linked in the "2D Instructions Corner" subassembly.
  1. Resolved an issue with Back Center Notch option in Adj Shelf subassembly where the notch was off center when turned on.
  1. Resolved issues with Doors and Drawer Fronts extending too far down when No Bottom is selected.  The Component Doors, Component Drawers, and Component Door Drawer subassemblies have been updated.
  1. Resolved issue with incorrect part size and location in Range Hood Master product.
  1. Resolved issue with Salice FF Hinges not drawing correctly for some of the Overlay options.  Also updated the available options in hardware file.
  1. Resolved issue with Wood Drawer Box when Rear Cutout is used with screw construction method where the Screw machine token was assigned to wrong part edge.
  1. Resolved an issue with Leg Leveler Base hardware drawings rotating incorrectly.
  1. Resolved an issue with Toe Kick Assembly Box not being represented correctly in 2D Plan and Elevation.
  1. Resolved an issue with 2D plan and elevation representations of Waste Pipe and Tap Outlet options in the Wall room component product. This will only be available with a new install or a transfer of the Wall product via Database Explorer.
  1. Resolved an issue with prompts not showing when adding a single door to the Wall room component product. This will only be available with a new install or a transfer of the Wall product via Database Explorer.
  1. Updated 2D section Top and Bottom Reveal dimensions to align with other dimension lines.
  1. Modified the drawing tokens for Adj Legs and Toe Kick Assembly Box to draw lines top and bottom.  It will only draw lines for left and right if it "Left/Right Finished End" is on or if "Left/Right Toe Kick" prompt is on in subassembly.
  1. Added the "LED Strip Lighting" prompt and subassembly to the relevant FF products.
  1. Added Divisions with Adj Shelves and Division with Fixed Shelves as options in the Horizontal Splitter FF and the Vertical Splitter FF.
  1. Resolved an issue in Master Split Vertical Designer Cabinet FF when the global Face Frame Miter FE Joint is checked. Applied Ends and Face Frame parts now miter correctly.
  1. Resolved issues in Master Split Height Designer Cabinet FF where the proper drawer quantity was not passing through correctly when selecting "Drawers for the Face" option in any bay.
  1. Resolved an issue with FF product drawing tokens where the Right Stile size annotation was incorrect. This has been resolved in the Face Frame, Rear Face Frame, Face Frame Quarter Round, Face Frame Open Corner, and Diagonal Angled Face Frame Drawing subassemblies.
