Microvellum Processing Center System Requirements
This document lists both the minimum and recommended system configuration for operating Microvellum's standalone Processing Center application. For more information about the standalone application, see the Microvellum Processsing Center Application article.
Minimum System Requirements
Operating System (64 bit): Windows 10 or Windows 11
Processor: 2.5-2.9 gigahertz (GHz) or faster processor. (Ex: Intel Core i5)
Memory: 8 GB RAM
Display Resolution: 1920x1080 with True Color, and 125% Desktop Scaling (120 DPI) or less.
Graphics Card: Most standard graphics cards will work.
Disk Space: 64+ GB SSD or HDD. Processing Center requires <1GB for installation.
Alert
Windows 32-bit is not supported.
Notes
Microsoft support for Windows 10 officially ended on October 14, 2025.
Processor: 3.0+ gigahertz (GHz) or faster processor. (Ex: AMD Ryzen 5)
Memory: 16 GB RAM.
Display Resolution: Device with resolutions up to 3840 x 2160 supported on Windows 10/Windows 11, 64-bit systems (with capable display card).
Graphics Card: Dedicated GPU with 1-2 GB VRAM or higher (for interoperability with other MV software).
Disk Space: 128+ GB SSD or HDD.
