PRESSPULL Command
PRESSPULL Command
Dynamically modifies objects by extrusion and offset.
Get visual feedback as you move the cursor after selecting a 2D object, an area formed by a closed boundary or a 3D solid face. The press or pull behavior responds to the type of object you select to create extrusions and offsets. In this example, the area between two polylines is pulled to create a 3D solid wall.
Selection
Presspull Behavior
Open 2D Object (Such as an Arc)
Extrudes to create a surface.
Closed 2D Object (Such as a Circle)
Extrudes to create a 3D solid.
Inside a Bounded Area
3D Solid Face
Offsets the face, expanding or condensing the 3D solid.
The command repeats automatically until you press Esc, Enter, or the Spacebar.
Object or Bounded Area
Select the object, bounded area, or 3D solid face that you want to modify.
Selecting a face extrudes the face without affecting the adjacent faces. If you Ctrl + Click a face, the face is offset, and the change also affects the adjacent faces.
Multiple
Specifies that you want to make more than one selection.
You can also Shift + Click to make multiple selections.
Offset Distance
If you selected the face of a 3D solid, specify the offset by moving the cursor or entering a distance.
Extrusion Height
If you selected a 2D object or clicked inside a closed area, specify an extrusion height by moving the cursor or entering a distance. The extrusion direction of planar objects is normal to planar objects and in the Z direction of the current UCS for non-planar objects.
Powered by AutoCAD®
