Module Definitions
Module Definitions
This article provides an overview of the modules available in Microvellum, along with a brief description of each.
2D & 3D Drawing
Enables all 2D and 3D drawing features within Microvellum.
A
Advanced Nest Tabbing
Enables tabbing functionality for Microvellum’s part nesting optimization.
B
Block Nesting Optimization
Provides specialized rectangular (block) optimization for rectangular parts used in nested-based manufacturing.
C
Custom DXF File Generation
Enables a custom DXF file format generation.
CNC Auto-Labeling
Enables output for CNC machines equipped with auto-labeling capabilities.
CNC Horizontal Boring Machine Code Output
Enables CNC horizontal boring machine code output.
CNC Machine Code Generation
Enables CNC machine specific g-code and individual part g-code program generation.
Common Line Cutting
Enables parts to be optimized and machined using a common line toolpath between parts. Common Line Cutting can reduce machine cycle times.
Custom CSV File Import
Enables a custom parts file import functionality.
D
DXF File Generation
Enables standard DXF file generation for all parts.​​​​​
I
Integrated Post Processor (IPP)
Activates Microvellum’s internal post processor for creating machine-specific G-code for one unique machine type.
M
Material Handler Connectivity
Activates connectivity to Biesse® Winstore® material handling system.
O
On-demand Labeling
Enables access to the label, pattern preview, and printing interfaces for sawing or nesting applications. For shop-based label printing at CNC-enabled saws or routers, a stand-alone Microvellum license is required for each station.
P
Part Labeling
Enables the generation of individual labels for all parts.
Parts File Custom Output
Enables generation of custom parts files (for example, parts files for automated cut-off saws).
Parts List for Ardis®
Enables the creation of part files specifically for ARDIS® software.
Parts List for Bluecell®
Enables the creation of part files specifically for Bluecell® from Eurosoft.
Parts List for Cut Rite®
Enables the creation of part files specifically for Cut Rite® software.
Parts List for Schelling® HPO
Enables the creation of part files specifically for Schelling® HPO saws.
Perfect Graining at Nest
Enables advanced nesting algorithms to optimize parts based on grain direction.
Perfect Graining for Ardis®
Enables graining information to be passed to Ardis®.
Perfect Graining for Cut Rite®
Enables graining information to be passed to Cut Rite®.
Perfect Graining for Microvellum Saw Optimizer
Enables advanced sawing algorithms to optimize parts base on grain direction.
Perfect Graining for Schelling® HPO
Print Ardis Parts Labels with Microvellum
Enables users to print part labels generated by Ardis® for optimized parts in Microvellum.
Processing Center
Enables access to the user interface for processing projects, defining processing stations, and generating reports.
Product Labeling
Enables the generation of individual labels for all products.
Project Costing & Estimating Reports
Enables access to Microvellum’s Activity Station Setup and Reporting functionality for project costing.
R
Report Designer
Enables access to the Report Designer for report and label creation and editing.
Run Face 6 Operations First
Enables processing of bottom-side (Face 6) machining first on nested sheets.
S
Sawing Code Generation
Enables optimization and machine-specific (saw) program generation for rectangular parts, with reports that include material type, quantities, and part dimensions.
Sawing Optimization
Enables part optimization on rectangular material for non-CNC production, with access to reports that include material type, quantities, and part dimensions.
Scrap Management
Enables tools to track and reuse scrap material for future saw and nest optimization.
Scrap Management for Material Handler
Enables scrap management features to work with  Biesse® Winstore®.  Is not compatible with other scrap management systems.
Single Part Editor
Enables the Single Part Editor in Toolbox, allowing changes to existing parts or creation of custom parts for products.
Solid Model Analyzer
Enables advanced analysis of 3D solids in Toolbox, generating CNC-ready Microvellum products.
Solid Modeling Tools: Custom Tools
Enables access to the Custom Tools within the Solid Modeling Tools palette in Toolbox for creating custom products, furniture, and cabinetry.
Solid Modeling Tools: Extruded Tools
Enables access to the Extruded Tools within the Solid Modeling Tools palette in Toolbox for creating architectural millwork, fixtures, and custom assemblies.
Spreadsheet Editor
Enables access to an advanced customization interface for editing the parametric formula logic of products.
Stay-down Nesting
Enables the nesting optimizer to generate patterns that use a single toolpath for all part borders within a nest.
T
True Shape Nesting
Enables optimization of irregular-shaped parts within the nesting optimizer, allowing complex part geometries to be nested efficiently.
W
Work Orders
Enables functionality for creation, importing, and exporting of work orders.
