The Range Hood - Add-on
About the Library Add-on
This is a “Master” Range Hood product capable of being used as is or saved back to the library numerous times in unlimited number of different combinations.  This Library Add-on is compatible with the Foundation Library. This article will provide you with an overview of the features included.
What is a Library Add-on?
Library Add-ons are considered stand-alone library data such as products, hardware, blocks or other materials.
Info
As of Microvellum Foundation Library build 26.0112, the Face Frame Library is integrated into the base Microvellum Foundation Library.
Range Hood Master
Main Options:
Projection Options:
  1. Side Offset - Distance to inset the projection from the end of the unit.
  2. Projection Side Angle - Enter a number in degrees to angle the sides of the projection. (0-89)
  3. Projection Depth - Adjust the product depth and Rear Face Depth to control.
  4. Projection Depth Top - Distance the slope is held off the wall at the top of the unit.
  5. Projection Height - Height of lower flat portion before slope
  6. Projection Arc Height - Height of projection arc.
  7. Slope Height - Height from top of lower projection to top of slope
  8. Bead Board options for Face and/or Slope
  9. Lower Projection Face/Ends options: Solid Panel/Veneer Panel/Door Panel/Carved Panel
  10. Lower Projection Top/Bottom Molding options
  11. “Keku Clip” Front Assembly option
  12. A table of Hood Fan Selection choices
  13. Custom Hood Cutout options
Example nest pattern:
