To begin drawing moldings, select the Moldings category from the drop-down menu. Select the preferred molding from the list. Right-click, or double-click to access the quick menu.
After adding a molding, a prompt interface will follow. The interface will allow you to specify the height above the floor, add comments, and select how the molding will be drawn and added to the project.
The option to Add Lineal Footage to Project will add a single product with the molding listed as linear footage based on the length of the polyline. Add Each Segment to Product will add a new product for each segment of the polyline. Draw Only draws the molding in the drawing, but no product(s) are added to the database.
