Save Subassembly to Template Check Prompts (Reference)
The purpose of this article is to provide a reference for the new Subassembly Save Options interface. This reference applies to Toolbox builds 15.6.2201 and greater.
See  Save Subassembly to Template Check Prompts (Overview)  in the Microvellum Help Center for an overview of this new interface.
Getting There
To begin, use the command Edit Design Data on a product to edit a prompt value of a subassembly.
Right-click on a subassembly row and select Show Subassembly File. Select the prompt tab at the bottom of the subassembly spreadsheet. Choose the desired formula-driven value and hard-lock it with a new value (see example below).
Fig. 1 – Example of Replacing a Formula with a Value
The “Subassembly Save Options” interface displays after saving the hard-locked values.
Fig. 2 – Subassembly Save Options
This interface offers two ways to save a subassembly – Save to Project, or Save to Library.
Fig. 3 – Save to Project Options
Fig. 4 – Save to Library Options
Saving Changes to the Project
Here is a list of the commands available when saving changes.
Save to Current Row  – Saves changes only to the current row.
Save to Product  – Saves changes only to the product.
Save to Project Overwrite Existing  – Saves changes at the project level and overwrites any existing data in the project.
Save to Project as New Subassembly  – Saves the subassembly to the project as a new subassembly. The user assigns a name to the new subassembly in the box and allows assigning it to the current row.
Fig. 5 – Save New Subassembly to Project Options
Saving Changes to the Library
If changes are made to subassembly prompts, selecting the radio button Overwrite Existing will activate the button Resolve Prompt Conflicts.
Fig. 6 – Overwrite Existing Activates Button
Clicking on this button will display the Resolve Subassembly Prompts interface.
Fig. 7 – Resolve Subassembly Prompt Interface
This interface provides a clear visual representation of the subassembly prompts changed by hard-locked values in the spreadsheet. It ensures library level subassembly prompt changes reflect the value(s) desired by the user. It enables users to select the checkbox Overwrite With Template. This causes the selected values to be overwritten with the “Template Value.”
Selecting the “Save as New Subassembly” radio button will allow the user to save and name a new subassembly to the library.
Fig. 8 – Save As New Subassembly
    • Save Subassembly to Template Check Prompts (Overview)
      The purpose of this article is to highlight the new interface and functionality when saving subassembly prompt(s) to the library level. When saving a subassembly back to the template and overwriting it, you can now check the modified subassembly ...
    • Microvellum Data Dictionary
      Microvellum Data Dictionary Introduction This manual is a guide to the Microvellum Factory and Work Order Databases. This manual has four sections. The first section includes this introduction, and the remainder is General Information about this ...
    • Understanding the Subassembly Save Levels
      Subassembly Save Levels When working in the Subassembly Prompts, there are different save options located at the bottom of the interface. Because subassemblies are shared across a project, multiple save levels have been incorporated to allow you to ...
    • Overview: Subassembly Save Options
      Microvellum builds 15.5.1405 or higher required. The program has been modified to improve the flexibility of saving subassemblies.  Previously, when creating a new subassembly, the program created the new subassembly in the library but did not create ...
    • Overview: Passing Prompt Information Between Workbooks (Subassembly)
      We have added the ability to pass custom information from the L! workbook (local prompts) to the S! workbook (subassemblies). Without that ability, the number of prompts is greater, and the complexity of formulas increases. When the formula ...
