Managing Your Software Activations
This article will help you understand the process of managing your software activations and deactivations.
All requests regarding software management should be made using our ticketing system. When creating a support ticket, you will be presented with two options - General Tech Support and Software Management.
If you need support related to the general operation of your Microvellum software, and would like to submit a ticket, choose the "Submit a Ticket" option in the Tech Support card. To submit a ticket regarding your general license information, software activations, software deactivations, issues with your activation, or to request a build update or software upgrade, click the "Submit a Ticket" in the Software Management card.
When you need to get help regarding your software management, be sure to select the correct option when selecting the reason for the request. Note: You will see red asterisks for the fields that are required.
  • General License Information – This should be selected for general questions regarding your serial numbers, obtaining a copy of your serial number and/or password or something similar.
  • Request Software Activation – This should be selected if a phone activation method is used when activating your software.
  • Request Software Deactivation – This should be selected when a license needs to be removed from a machine.
  • Activation Issue – This should be selected when having difficulties activating your software.
  • Build Update Request – Select this option to request an update to your current software.
  • Upgrade Request – Select this option to request an upgrade to your current software. (i.e., upgrading your OEM version.)
    • How to Request a Software Activation
      At times, there may arise a need for software activation or reactivation, whether for an initial setup or a reinstallation. Normally, with an active internet connection, your software undergoes automatic activation over the internet, seamlessly ...
    • How to Request to Deactivate a Software Activation
      At times, there may arise a need to deactivate a software license. The cause for this may vary but is often related to the need to transfer activations from one computer to another. The following steps will guide you through the process of ...
    • How to Request a Software Build Update
      Software maintenance updates offer valuable improvements, including bug fixes, performance enhancements, and new features that enhance functionality and user experience. Not to be confused with “upgrades”, updates include incremental changes to your ...
    • How to Request General License Information
      Requesting general software licensing information from Microvellum may be necessary for several reasons: Understanding Licensing Terms: You may want to clarify and understand the terms and conditions of your software license. This can include details ...
    • How to Run an Update for Toolbox
      This article covers the steps involved in updating your Microvellum Toolbox Software Installation. Before updating, we recommend reviewing our Pre-Installation Instructions and creating a backup of your data. For information on creating a backup see ...
    • Toolbox Release Notes | Build 25.1.1218.641
      The following release notes apply to Toolbox build 25.1.1218.641 Part Properties Fixes A handful of issues centered around the Part Properties interface have been resolved: The Reference for Measurement tool in the interface has been fully removed ...
    • Transferring Global Variables to a new Library
      This article will explain the process of transferring customized Global Variables from your current library to a new installation of the Microvellum Foundation Library. The G! Workbook The Foundation Library contains all standard and custom data in ...
    • Microvellum Foundation Library Release Notes | Build 25.1121
      The following release notes apply to the Microvellum Foundation Library build 25.1121. Additions Added the new product, Master Island End Cabinet, to the Master Cabinets FF product category. Added the Nesting Optimization Report Select Processing ...
    • Toolbox Release Notes | Build 25.1.1204.641
      The following release notes apply to Toolbox build 25.1.1204.641 Toolbox Login Screen Update Fig. 1: The updated Toolbox Login interface. The Toolbox Login interface has had several changes applied to it to enhance its usability and allow for greater ...
    • Toolbox Release Notes | Build 25.1.1120.641
      The following release notes apply to Toolbox build 25.1.1120.641 Mouse Wheel Fix There was a reported issue in certain interfaces (such as report groups) in which hovering over a dropdown menu (such as Output Type) would result in the options within ...
