Toolbox Commands List
Info
This article lists all of Microvellum's custom commands. To learn how to map Toolbox/AutoCAD functions to keyboard shortcuts, or learn the difference between Microvellum's custom Toolbox commands and basic AutoCAD commands, consult the following articles:
Microvellum Commands vs AutoCAD Commands
Toolbox Keyboard Shortcuts
The Toolbox commands provide a quick way to access Microvellum specific functionality. Each of these commands may be entered on the Toolbox Command Prompt.
The Command list includes an autocomplete feature, as shown below.
Below is a list of the available commands. A download of this list is available at the bottom of this article.
Microvellum Commands List
MVABOUT – Displays the About Microvellum screen.
MVADDNEWEMPTYPRODUCT – Adds a new empty product to the product list.
MVADDPARTLABELS – Creates labels for all parts of a product.
MVADDPRODUCTLABEL – Creates a label for a product.
MVADJUSTWALLLENGTH – Changes the length of walls and products.
MVADVANCEDLIBRARYSETUP – Manages specification groups at the library level.
MVADVANCEDPROJECTSETUP – Manages specification groups at the project level.
MVALIGNPRODUCT – Aligns products in model space.
MVASSOCIATEPRODUCTSTOWALL – Links a product to a wall.
MVBROWSETODATA – Opens windows explorer to the data folder.
MVBUMPPRODUCT – Moves a product next to another product.
MVCHANGEDOORSTYLE – Changes the door style of a cabinet.
MVCONTACTS – Manages Contacts.
MVCOPY – Copies Products.
MVCREATENEWWORKORDER – Opens the work order creation interface.
MVCREATENEWWORKORDERFROMDRAWING – Select products in the drawing to include in a new work order.
MVDATABASEEXPLORER – Launches Database Explorer dialog.
MVDATABASEUTILITIES – Launches Database Utilities dialog.
MVDRAW2DPRODUCTS – Creates a 2D drawing of a complete product, placed at a selected point.
MVDRAW2DWALLS – Creates a 2D elevation wall.
MVDRAWCENTERLINEPATH – Draws centerline path of a route.
MVDRAWCROSSSECTION – Draws a cross-section of a product.
MVDRAWDYNAMICPRODUCTIMAGES – Draws a dynamic image of a product at a selected point.
MVDRAWFACEFRAMETOKENS – Draws 2D Face Frame Tokens at a selected point.
MVDRAWHATCHEDRETURN – Draws a side profile of a product.
MVDRAWPARTIN2D – Draws a part in 2D and launches Single Part Editor.
MVEDITDESIGNDATA – Opens spreadsheet to edit product data.
MVEDITEXISTINGWORKORDER – Opens a work order in the processing center.
MVERASE – Erase products.
MVEXPLODEPRODUCTS – Moves parts of a product away from each other by a specified factor.
MVGROUPPRODUCTS – Creates a product group and adds it to the database.
MVJOINPRODUCTELEMENTS – Joins specified product elements together.
MVJOINPRODUCTS – Joins two or more products into one.
MVMAKENEWGCODEFROMDRAWING – Makes new G-Code from drawing.
MVMAKEWINDOWSMETAFILE – Creates Windows Metafile for a product.
MVMIRROR – Creates a mirrored copy of a product.
MVMOVE – Moves Products.
MVOPTIONS  Opens the Options menu within Toolbox Setup.
MVOVERDRIVEPRO – Opens the Product List.
MVPARTPROPERTIES – Edit properties of parts.
MVPARTSLIST – Creates a label with the list of parts in a product.
MVPEDIT – Edit a Polyline. (This command is currently known to cause errors in the software, and as such, is not recommended for use).
MVPROCESSINGCENTERS – Edit processing stations.
MVPRODUCTDRAWINGSETUP – Edit product dimension settings.
MVPRODUCTPROMPTS – Edit the prompts of a product.
MVPROJECTPROPERTIES – Opens the project properties interface.
MVREDRAW2DWALLS – Redraws selected 2D walls.
MVREDRAWSELECTEDPRODUCTS – Redraws selected products.
MVRENUMBERPRODUCTS – Changes the number of a product. When prompted, enter the new number in the command line, then click on the product. The product's number will be increased by .1 with every subsequent click, allowing for multiple products to be renumbered chronologically.
MVREFRESHITEMNUMBERS – Syncs product item numbers of Products.
MVREPLACE – Replaces a product with a different type of product from the library.
MVROTATE – Rotates a product by a specified angle.
MVSAVEPRODUCTTOLIBRARY – Select a product and save it to the currently active library in a category of your choice.
MVSHOWTOOLFILE – Edit settings of primary toolfile.
MVSINGLEPARTEDITOR – Launches the Single Part Editor palette.
MVSMARTLAYERMANAGER – Manages MV smart layers.
MVSOLIDMODELANALYZER – Converts CAD objects into MV products.
MVSOLIDMODELINGTOOLS – Launches the Solid Modeling palette.
MVSOLIDPROPERTIES – Edit the properties of solid models.
MVSUPPORTPORTAL – Opens the Microvellum Support website in an internet browser.
MVSUBASSEMBLYPROMPTS – Opens the prompts of a selected subassembly.
MVUPDATEGCODEFROMDRAWING – Updates Existing G-Code from drawing.
MVWALLSSETUP – Edit wall settings.
    • Microvellum Commands vs AutoCAD Commands
      Toolbox, as an OEM based on AutoCAD, possesses the full range of AutoCAD commands for use in accessing AutoCAD functions, such as drawing shapes, opening menus, altering the dimensions of polylines, etc. However, it should be noted that when working ...
    • AutoCAD Keyboard Commands
      Learning how to use AutoCAD keyboard commands can help you work faster and improve your efficiency. This article lists the abbreviated commands that can be used in AutoCAD (Toolbox). Toggle General Features Ctrl+G Toggle Grid Ctrl+E Cycle isometric ...
    • Toolbox Keyboard Shortcuts
      This article is a tutorial for setting up your system with your favorite keyboard shortcuts using Microvellum commands. This article explains the process for setting up keyboard shortcuts using Microvellum's custom Toolbox commands. For a full list ...
    • Commands for Materials and Textures
      These commands are used to work with materials and textures. Commands CONVERTOLDMATERIALS Converts older materials to use the current materials format. Materials that were created in a previous materials format are updated to the current materials ...
    • To Work with Entering Commands
      How to enter a command on the command line.  Enter a Command on the Command Line Enter the command using one of the following options:  In the command prompt text box, type the full command name and press Enter or Spacebar.  If the automatic command ...
    • Toolbox Release Notes | Build 25.1.1218.641
      The following release notes apply to Toolbox build 25.1.1218.641 Part Properties Fixes A handful of issues centered around the Part Properties interface have been resolved: The Reference for Measurement tool in the interface has been fully removed ...
    • Transferring Global Variables to a new Library
      This article will explain the process of transferring customized Global Variables from your current library to a new installation of the Microvellum Foundation Library. The G! Workbook The Foundation Library contains all standard and custom data in ...
    • Microvellum Foundation Library Release Notes | Build 25.1121
      The following release notes apply to the Microvellum Foundation Library build 25.1121. Additions Added the new product, Master Island End Cabinet, to the Master Cabinets FF product category. Added the Nesting Optimization Report Select Processing ...
    • Toolbox Release Notes | Build 25.1.1204.641
      The following release notes apply to Toolbox build 25.1.1204.641 Toolbox Login Screen Update Fig. 1: The updated Toolbox Login interface. The Toolbox Login interface has had several changes applied to it to enhance its usability and allow for greater ...
    • Toolbox Release Notes | Build 25.1.1120.641
      The following release notes apply to Toolbox build 25.1.1120.641 Mouse Wheel Fix There was a reported issue in certain interfaces (such as report groups) in which hovering over a dropdown menu (such as Output Type) would result in the options within ...
