Toolbox OEM vs Standard AutoCAD
Although most features of Toolbox OEM are exactly the same as their counterparts in AutoCAD, there are several differences. In addition, Toolbox OEM defines a few native commands and system variables that do not exist in AutoCAD.
Differences in Features and Utilities:
Toolbox OEM does not support the following features:
  1. Autodesk Apps Store
  2. Embedded VBA macros
  3. Express Tools
  4. InfoCenter
  5. Geographic location information with online maps
  6. Online Share
  7. Profiles tab of the Options dialog box
  8. Shared views
  9. Save to/Open from AutoCAD Web & Mobile
  10. Drawing History
  11. Recent blocks from the Blocks palette
  12. VLX files compiled with the Visual Lisp IDE or MAKELISPAPP command
Unsupported System Variables:
Toolbox OEM can use most of the Standard AutoCAD system variables; however, the following system variables are not supported:
  1. ACADVER
  2. ACADPREFIX
  3. LOGINNAME
  4. MENUCNTL
  5. PDFSHXLAYER
  6. PDFSHXTHRESHOLD
  7. POPUPS
  8. SCREENBOXES
  9. SCREENMODE
  10. SECURELOAD
  11. SECUREREMOTEACCESS
If you are looking for a way to migrate the CUI from a Standard AutoCAD installation to the OEM, consider reviewing the following article:
    • Toolbox Release Notes: 2020-2025
      This document will catalog all Microvellum Toolbox software builds that were released in the years of 2020-2025. This encompasses builds 20.1.0203.641 to 25.1.1204.641 (current). Year of 2025 This section catalogs all Microvellum Toolbox software ...
    • What’s New in Toolbox 2025 (OEM)
      Work smarter, faster with Toolbox 2025 (OEM). With an OEM Subscription, you’ll gain access to the latest toolsets and innovative features of Toolbox 2025. Improvements Toolbox UI Overhaul OEM 2025 introduces several updates to the appearance and ...
    • What's New in Toolbox 2021 (OEM)
      Work smarter, faster with Toolbox 2021 (OEM). With an OEM Subscription, you’ll gain access to the latest toolsets and innovative features of Toolbox 2021. Here are a few added features found in the OEM 2021 release: Improvements to the Blocks ...
    • What's New in Toolbox 2020 (OEM)
      Toolbox 2020, OEM, is packed with new features and enhancements to help you streamline your design, drafting, and engineering. With an OEM Subscription, you’ll gain access to the latest toolsets and innovative features of Toolbox 2020.  Improved Dark ...
    • What's New in Toolbox 2023 (OEM)
      Work smarter, faster with Toolbox 2023 (OEM). With an OEM Subscription, you’ll gain access to the latest toolsets and innovative features of Toolbox 2023. Improvements Floating Drawing Windows Right clicking the title bar and selecting Move to File ...
    • Toolbox Release Notes | Build 25.1.1218.641
      The following release notes apply to Toolbox build 25.1.1218.641 Part Properties Fixes A handful of issues centered around the Part Properties interface have been resolved: The Reference for Measurement tool in the interface has been fully removed ...
    • Transferring Global Variables to a new Library
      This article will explain the process of transferring customized Global Variables from your current library to a new installation of the Microvellum Foundation Library. The G! Workbook The Foundation Library contains all standard and custom data in ...
    • Microvellum Foundation Library Release Notes | Build 25.1121
      The following release notes apply to the Microvellum Foundation Library build 25.1121. Additions Added the new product, Master Island End Cabinet, to the Master Cabinets FF product category. Added the Nesting Optimization Report Select Processing ...
    • Toolbox Release Notes | Build 25.1.1204.641
      The following release notes apply to Toolbox build 25.1.1204.641 Toolbox Login Screen Update Fig. 1: The updated Toolbox Login interface. The Toolbox Login interface has had several changes applied to it to enhance its usability and allow for greater ...
    • Toolbox Release Notes | Build 25.1.1120.641
      The following release notes apply to Toolbox build 25.1.1120.641 Mouse Wheel Fix There was a reported issue in certain interfaces (such as report groups) in which hovering over a dropdown menu (such as Output Type) would result in the options within ...
