Toolbox Release Notes | Build 21.1.1210.641
The following Release Notes apply to Toolbox Build 21.1.1210.641
3D Drawings
Resolutions:
  1. Resolved an issue with the 3D representation of parts containing a Polyline machine token with a Z-value offset greater than 0.
Integrated Post Processing
Resolutions:
  1. Resolved an issue where some posts were causing an integrated post processor error.
Reports & Labels
Resolutions:
  1. Resolved an issue where values on label images were rounding to the nearest whole number in MV Server.
  2. Resolved an issue where Edgename information fields were not being populated on some reports.
  3. Resolved an issue where a Cutrite ASCII saw would only print .wmf or .bmp file types despite all image types being available for selection.  All types will now print.
  4. NOTE: When using Cadmatic version 3 in conjunction with a Cutrite saw, you must set the Part Picture Type to "BMP" in order for the part image to display correctly on your labels.
