Toolbox Release Notes | Build 22.1.0325.641
The following Release Notes apply to Toolbox Build 22.1.0325.641
Toolfile
Resolutions:
  1. Resolved an issue in certain post names where the pecking number was not working.
  2. Resolved an issue in certain post names where some face 6 machining was falling off the part when it had a quantity greater than 1.
  3. Resolved an issue in certain post names that prevented the multi-pass order from working when face 6 machining was flipped to face 5.
  4. Resolved an issue where certain routes had a lead-out that ramped when it should not have.
  5. Resolved an issue in certain post names where the face 6 file name in the Gcode did not match the file name output on disk.
  6. Resolved an issue in certain post names where rotated parts with machining on both sides were getting length/width measurements swapped in face 6.
  7. Resolved an issue in certain post names when “Allow Vertical Drills” was turned off, the program would not close because it had unwritten drills.
  8. Resolved an issue in certain post names that caused “Remove Duplicate Gcode” to remove duplicate Gcode in a nesting station (this should not happen in a nest).
Processing
Resolutions:
  1. Resolved an issue where router feed speeds were being overwritten by the material override for the entire work order process. It is now using a copy of the router tool to change feed speeds.
  2. Resolved an issue that prevented processing when certain parts had edgeband on all four sides with a thickness of .01.
  3. Resolved an issue where the diameter of the H-drill was being rounded to the nearest tenth. This was causing 9.525 to be truncated to 9.5.
Machine Tokens
Resolutions:
  1. Resolved an issue where the PLINE token's 6th and 7th parameter would ignore any decimals.
Material UI
Resolutions:
  1. No longer including brackets in copied materials. Materials now use an underscore when copied.
