Toolbox Release Notes | Build 22.1.0525.641
The following Release Notes apply to Toolbox Build 22.1.0525.641
Database Management
Resolutions:
  1. Resolved an issue that caused products and subassemblies to need to be imported twice in order to see them in Toolbox.
  2. Resolved an issue with apostrophes ( ‘ ) in the project name that prevented the handling of duplicate projects.
  3. Resolved an issue that prevented products from being drawn in a project. This issue only happened in very rare situations but is handled now.
  4. Resolved an issue with subassembly and product categories not being deleted correctly.
Modifications:
  1. Minor updates made to the Database Management UI.
  2. Before:
  3. After:
  4. Added a “Select All” pop-up message if multiple Database Records are detected during import.
Edit Design Data
Modifications:
  1. Added the ability to hide Subassembly Prompts if the Prompt Values column is using them. Dimming or disabling the subassembly prompt value prevents users from making unintended mistakes.
Tool File IPP
Resolutions:
  1. Resolved an issue that caused certain tool files to skip drill pecking when writing gcode.
  2. Resolved an issue with some Weeke tool files that caused the perimeter lead in/out route to be incorrect.
  3. Resolved an issue with some Weeke tool files that was causing incorrect unit conversion of the arc radius on nesting operations.
