Toolbox Release Notes | Build 22.1.1010.641
The following Release Notes apply to Toolbox Build 22.1.1010.641
Nest Editor
Resolutions:
• Resolved an issue where moving parts to a new sheet in a composite drawing would cause discrepancies.
• Resolved an issue where changing the border setmill in a nest on certain shaped parts would create an invalid part border.
• Resolved an issue where adding additional tabs to small parts would create an arithmetic error.
• Resolved an issue where copying a part in a nest where 4-digit filenames have been turned on will result in a 5 digit filename.
Single Part Editor
Resolutions:
• Resolved an issue where canceling while drawing a route would cause a polyline to be drawn at the origin of the part.
• Resolved an issue where adding additional face 6 machining to a part will move the existing face 6 machining after the part is updated.
• Resolved an issue where adding a round pocket in 2D when the diameter of the tool and circle are the same would create an error.
• Resolved an issue where trying to update a part from 2D from an unopened project would produce an error.
• Resolved an issue where reversing the polyline of a route would alter the part name.
Library Materials
Resolutions:
• Made further modifications to project and template workflows where certain events would cause project materials to get saved to the template.
Microvellum Server
Resolutions:
• Made further modifications to the error logs that server produces to have better links to the products that caused the errors.
