Toolbox Release Notes | Build 23.1.0329.641
Processing Center
Resolutions:
- Resolved an error in the ‘View Nesting G-Code Results’ UI when trying to view DXF’s.
- ‘Modify Work Order’ will no longer remove certain edge band information if editing that material.
Modifications:
- Modified new installs to have the ‘Auto-Load Parts’ setting enabled by default.
- Users will now receive a notification that the reports in report groups have been output or not.
SQL Database
Resolutions:
- Resolved a file sharing violation that could occur in SQL databases because the software wasn’t closing its connection to the SDF or has it in memory.
Materials
Resolutions:
- Resolved an issue with evaluating edge band tokens properly if ‘Find and Replace’ was used on an edge band material in a project.
- Materials not associated to a pointer no longer become disassociated from the project workbook after using ‘Find and Replace’.
Part File Names
Resolutions:
- Resolved an issue that caused file names to increment wrong because the software was holding the last file name used in memory. The count should restore from the database, not 1 PC’s memory.
Modifications:
- We have improved the efficiency of file names. We used to grab all part names, even if they were not being used in the product when the work order was created. The software is now incrementing file names according to the actual amount of part names that have quantity greater than 0 and exclude any part names that are 0.
