Toolbox Release Notes | Build 23.1.0808.641
The following Release Notes apply to Toolbox Build 23.1.0808.641
2D Drawing Overhauls
Fixes
Before | After |
Figure 1: 2D font error. | Figure 2: 2D font fix. |
- An issue was noted and resolved wherein creating 2D drawings of 2 identical products caused the fonts on the 2D drawings to mismatch or otherwise come out incorrectly.
Figure 3: Product sections crash.- Users reported an issue wherein Toolbox would crash if users selected the “Don’t Use Drawing Tokens” option while drawing product sections, then clicked “Pick Cutting Plane”.
- An issue was noted and resolved wherein the FaceFrame text was unable to be changed or be affected by the input for some users.
- There was a noted issue with products in copied rooms with simultaneous 2D elevation and 2D plan views, with the combination causing an error after redrawing the product. This issue has been resolved.
- There was an issue wherein 2D text objects would give the "Invalid Selection" error after certain commands in Modify Products were used. This issue has been resolved.
- Within Drawing Tools, there was a noted issue wherein clicking in blank cells would cause an error for users. This issue has been resolved.
Modifications
Figure 4: 2D wall elevations no duplicates.- The ability to create two 2D wall elevations has been altered: a pair of 2D drawings will no longer support the same product. If users modify the data, only a single drawing will update. If an attempt is made, users will be presented with a message notifying them of this change in association.
Figure 5: New 2D/3D error message.- An error message that would display when users attempted to use the option Draw Part In 2D on a 3D hardware block was deemed to be insufficient in terms of accuracy and semantics. As such, it has been revised to display more specific information on the problem.
