Toolbox Release Notes | Build 23.1.0901.641
The following Release Notes apply to Toolbox build 23.1.0901.641
Saw Oversizing Fix
Figure 1: Sawing oversize report issue.
  1. There was a reported issue with selecting a part to oversize: in the saw optimization processing station, enabling an oversized part would result in an inaccurate cut part size in the resultant saw optimization report, with the report failing to account for the differences in measurement between the basic measurement and the oversized measurement. This issue has been resolved- oversizing a part should result in a correctly generated size on the report.
Seeing this fix will require users to update their reports to the latest version.  Check the Sawing Optimization Reports download page and import the with the Database Management feature.
Barcodes STK File Fix
Figure 2: Barcode STK issue.
  1. An issue was reported wherein barcodes generated during processing would fail to generate to STK files. When processing an order utilizing an IPP Toolfile, the barcode would not generate within the resultant batches, though this noticeably did not occur when utilizing SS Toolfiles. This issue has been resolved- barcodes should now properly generate in both types of Toolfiles.
New Polyline Bulge Parameter
Figure 3: New DRAWPOLYLINE parameter.
  1. A longstanding issue with polyline bulge values in drawing tokens has been fixed. The DRAWPOLYLINE drawing token has had a new parameter added to it to prevent an issue wherein an opposing bulge pattern from the OFFSETPOLYLINE spreadsheet function would cause errors if the two were used in conjunction. The new parameter controls polyline bulge direction, allowing users to choose between the two while keeping the direction consistent.
This is considered a breaking change. See the Breaking Changes log for more details.
Room Categories Fix
  1. Users reported an issue wherein rooms would not save to categories assigned to them, but instead, after closing, revert to their original category or otherwise fail to register their new category within the interface. This issue has been resolved- rooms should remain in their set category in the interface.
Face 6 Mirror Imaging Fix
  1. An issue was found wherein WMF images created from 2D parts that were created while the “Machine Mirror Part” setting was enabled would fail to rotate or flip face 6 2D parts, specifically failing to flip on the X axis, resulting in incorrect looking WMF files. This issue has been resolved- WMF images should now be unaffected by the "Machine Mirror Part" setting.
