Toolbox Release Notes | Build 23.1.1010.641
The following release notes apply to Toolbox build 23.1.1010.641
Extruded Products Fix
Figure 1: Pick Points extrusion issue.
  1. There were reportedly issues occurring when using extruded products, namely, a problem of failure to register extruded products in the proper category. When creating pick points for extrusion, the option noticeably did not appear in the menu. Moreover, there was an issue wherein multiple extruded products would not be designated as extruded, only being categorized as extruded if the first product in the list was designated an extruded product, and the rest were not. There was also an issue with copying extruded products via the database explorer, wherein the copies themselves were not marked as extruded in the database. Both issues have been resolved- extruded products should no longer have problems in categorization or copying via the database manager, and the pick points option should appear in the menu as intended.
PTX Oversize Option Fix
Figure 2: PTX Oversize change.
  1. A recent Toolbox build added a new option for users to utilize while oversizing parts in the sawing processing station, if using a PatternExchange saw as their output type. Users reported there was an issue within this new option, wherein the values from CUTS would not be displayed in the G-code, not being present in the PARTS_REQ string. This issue has been resolved- the option has been altered so that when enabled, the PARTS_REQ and CUTS values will be equal, and when disabled, will adhere to the default of different values.
Library Update Utility Overhauls
The Library Update Utility have had several overhauls to increase the overall functionality of the features, as well as numerous fixes to issues that were reported by users. The issues resolve include:
  1. A problem with the minimum size of the Resolve Duplicates window.
  2. An issue importing extruded products, as well as the (aforementioned) disappearance of the "Pick Points for Extrusion" option. (If the product is marked as "Extruded" in the name, it will now be designated as extruded in the product database.)
  3. A fix to allow for the update of existing combo box values.
  4. Imported materials should now be retain existing categories, rather than placed as a new category in their own individual folder. (Imported materials will now be using the Database Manager utility by default).
  5. Problem with Global Variables sometimes not updating with the Library Update Utility bringing in new Global Variables.
  6. The "Restore" option not removing sheets when updating SQL Servers.
  7. The addition of a "Delete" functionality for Library Update Utility (variables, look-up tables, etc.)
