Toolbox Release Notes | Build 23.1.1114.641
The following release notes apply to Toolbox build 23.1114.641
Tooltips Fix
Figure 1: Tooltips overlapping issue.
  1. There was an issue within the UI when hovering over the “Remove Material Trim from Scrap”. Rather than displaying a single tooltip, the UI would display two tooltips that overlapped with one another, displaying the original tip and the most recently updated tip simultaneously. This issue has been resolved- only the most recent tooltip should now pop up if the option is hovered over.
Rebuild Subassemblies Fix
  1. Users reported an issue wherein projects created in previous builds of Toolbox would have an error recurring upon attempting to rebuild the project’s subassemblies. When certain older projects were imported into a newer version, an object reference error would pop up, and when modified, the subassemblies noticeably did not change when rebuilt, until all of the subassemblies in the project had been rebuilt, at which point, they updated. This issue has been resolved- subassemblies from older versions should now be able to be updated in later versions without the error occurring.
Work Order Fix
Figure 2: Router drill duplication error.
  1.  There was a noted issue that occurred when users attempted to process work orders containing products that were assigned to use a router drill for drill holes. In work orders containing products with multiple quantities, drilling applied, assigned to a router drill for its drill holes, an error occurring during the processing, wherein the products would be read as duplicates and the software would register the products as the same item. This issue has been resolved, the error should no longer pop up, and the products with router drilling should properly register within the software.
