The following release notes apply to Toolbox build 23.1.1219.641
FLA Fixes
There was an issue with users who switched licenses from an FLA license to an SLA license having their software or session disconnected, and thus, being locked out of the session by the software.
- Sometimes, users who had successfully activated their software via online connection would have an error occur that locked them out of the software.
- There was an issue wherein users who had a software crash would be locked out of the session upon attempting to start a new session.
- All of these issues have been resolved- users should no longer have significant issues with session management when changing licenses, should no longer have an error occurring when activating their software, and software crashes should no longer result in users being locked out of the existing session.
Note: When changing from an FLA to an SLA license, it is important to ensure, prior to activating your new license, that you are:
A. Not checked out on your FLA.
B. Have a stable connection to the internet to facilitate the switch.
UI Fixes
A small handful of fixes for the Microvellum UI have been added to the software.
- There was an issue with network sessions, wherein the computer name for user computers would sometimes, when being checked out with the correct key, would display as “unknown”, leading to difficulty diagnosing issues within the session due to the lack of device information. This issue has been resolved- user devices should now display the registered device name when connected properly.
Figure 1: Learn more connection issue.- The “Learn More” link within the splash screen at the end of the informative sentence regarding login information would reportedly lead users to a defunct webpage, leading to only the Microvellum.com homepage. This issue has been resolved- the link is now operable and will lead to an existent knowledge base article pertaining to login security.
2D Drawing Fixes
Users reported a handful of issues occurring when creating 2D drawings of products.
Figure 2: Incorrectly sorted layer (left) and correctly sorted layer (right).- Some users noted an issue when creating a 2D drawing of a product part wherein a specific line on a specific section of the part was erroneously assigned to the wrong layer. This issue has been resolved- layer names for lines in a drawing should now display as different between every part.
Figure 3: Product number placement issue.- There was a reported issue with 2D drawings wherein the product number would show in a displaced location in the .dwg, with item number prompts not being able to relocate it successfully. This issue has been resolved- item numbers should be placed properly within products, and the existing item placement prompts should maintain their degree of control over the item numbers.
Figure 4: Scale issue (left) and fix (right).- When creating 2D section drawings with dimensioning applied, there was sometimes an issue occurring, wherein the dimensions would display incorrectly, at an incorrect location. This issue has been resolved- 2D dimensions in 2D drawings should now display correctly, in the correct positions, without issue.
- When checking one’s wall setup, it was noted by some users that the dimensions for the wall were reportedly not verifying. This issue has been resolved- the dimensions should now show as being verified if verified.
Figure 5: Incorrectly corresponding annotative scaling (top and bottom).- When not using annotative scaling, there was an issue wherein the text for FE and adjustable shelves would not correspond with entered values. This issue has been resolved- text should now scale correctly in correspondence with user entered values.
Tabbing Fix
Figure 6: Tabbing cleanup issue (top) and fix (bottom). - There was a reported issue with tabbing that occurred when users utilized certain Biesse brand Toolfiles, wherein tabs that were automatically placed on parts were also assigned to be cut off the part. In these circumstances, tabs would be placed on the wrong face, and when the operation was processing, would not be cut off the part correctly, leaving a piece of tab that required manual cutting to be corrected. This issue has been resolved- tabs should now be cut off accurately and in accordance with the intended cleaning off of the part without issue.
