Toolbox Release Notes | Build 24.1.0227.641
The following release notes apply to Toolbox build 24.1.0227.641
UI Fixes
Figure 1: Expansion issue with Function Arguments window.
  1. There was a noted issue regarding the Function Arguments window in the Formula Editor: when one expanded or increased the width of the window, multiple points of the UI and a few buttons would be cut off, with only certain parts of the UI expanding with the window. This issue has been resolved- the UI should now Function Arguments window should expand properly without cutting off any windows or text.
Figure 2: Illegal character dialog window, lacking a "Do Not Show Again" checkbox.
  1. Some users encountered an issue with the software’s dialog windows: when users generate reports with illegal characters, their reports will have the characters removed without issue to ensure the report generation is not delayed. However, the dialogue box informing users of the change in characters would appear without a “Do Not Show Again” checkbox, leading to issues when multiple words with illegal characters are within a single report, with users having to click “OK” on every individual change. This issue has been resolved- a “Do Not Show Again” button has been added to the UI.
Worklist File Fix
  1. There was an issue reported centered around the creation of .DAT files. When users generated a .DAT file containing data from a work order, with the option to separate out G-code files by material switched off, the .DAT file would still generate separated by material, regardless. This issue has been resolved- .DAT files with G-code not separated by materials should no longer display materials in the data.
Saw Processing Station XD Fields
  1. Saw Optimizers have had Extended Data fields added to the Custom Info Fields list.
PTX Oversize Parts UI Fix
Figure 3: Exclude Oversize Parts" setting.
  1. An issue with the UI of the “Exclude Oversize in PARTS_REQ” setting for the PatternExchange saw has been noted, wherein the setting would be visible regardless of one’s saw output type, when it should only appear if one is utilizing PatternExchange saws for output. This issue has been resolved- the setting should now only display if one’s output is PatternExchange.
Associative Hardware Cutout Fix
  1. There was a reported issue occurring with cutout tokens, wherein a cutout token would not display or machine properly on parts in a stack. This would sometimes occur in different ways, such as parts having 3D cutout representations, but no machining, or vice-versa. This issue has been resolved- Cutout machine tokens should display and machine properly on parts in a stack.
