The following release notes apply to Toolbox build 24.1.0312.641
Processing Station IDs
- Processing stations will have IDs added to them as an option within the Toolbox UI, to better distinguish between different processing stations.
Perfect Graining Fixes
- An issue was reported by users regarding copying materials with graining applied. Namely, when users copied a grained material with a tooling code to their project specification group, then opened the material workbook to find said material, it wouldn’t appear. The columns where the material should be placed are not populated. This issue has been resolved- materials with graining and a tooling code applied should now display correctly in the material workbook.
Figure 1: Erroneous negative Z warning.- There was an issue found wherein users would get an error incorrectly warning them that products they had in their project would not have perfect graining apply due to the negative Z value of said products. This was despite some of the products not having perfect graining applied, as well as none having a -Z value. This issue has been resolved- parts should have their values identified properly, and the error warning should no longer appear when it is not applicable.
- There was a reported issue experienced by some users wherein the PTX file created from the processed batch would not display any information relating to the grain container, which would show as 0.0. This issue has been resolved- grain container values should now display properly on PTX files with all properly input values calculated.
Microvellum Server Fixes
Several additional features and changes have been made to the UI of the Microvellum Server setup.
- Dividing lines have been added to the end of XML processing in the server event log.
- Microvellum Server has been modified to only restart upon processing XML files.
- A reported issue wherein certain errors (such as “product missing”) would not show on the event log has been resolved.
- A sometimes-occurring issue of the server experiencing a UI based bug and crashing has been resolved.
3D Representation Fixes
Figure 2: Misshapen corner issue on a product.- An issue wherein certain products would have issues with their cutout corners not having correct shape in their 3D representations has been resolved. Products with shapes like rounded corners should no longer run into issues of misshapen corners.
Figure 3: Angled dado misaligned (left) and fixed (right).- Issues were reported by users who experienced problems with the 3D representation of products with angled dados. The products would sometimes have parts misaligned with the whole of the product. This issue has been resolved- angled dados should display the exact angle value and no longer have issues of misalignment in 3D representation.
Figure 4: A product with a missing dado token (red).- There was sometimes an issue wherein products would have their dado machining disappear upon changing the values in certain prompts and redrawing the product. This issue has been resolved- dado tokens should no longer disappear from products, regardless of values changed within the product.
Figure 5: Door tombstone profiles not displaying in 3D (left) and displaying post-fix (right). - Users reported an issue with the profiles of doors not correctly appearing in 3D. When products with certain door profiles were drawn in 3D, the drawing would not display the polylines representing the door profiles. This issue has been resolved- door profiles should display correctly in the 3D drawing.
