The following release notes apply to Toolbox build 24.1.0513.641
PTX Saw Fix
Figure 1: Code generated on a PTX Saw with incorrect corresponding values (left) and corrected values (right). - An issue was reported wherein work orders assigned to the PTX saw would have parts of the of the code display incorrect dimensions, such as the cut part size displaying the values of the finish size. This issue has been resolved- processing parts through a PTX saw should no longer result in any issues with the output of a product.
Registry Modification
Figure 2: The Data Access tab of Toolbox, where a new check has been added on Data Source and Data Catalog. - An issue has been reported, wherein the Data Source or Data Catalog entry within the Registry would be deleted or set to zero seemingly at random, leading to crashes and software freezes in the middle of software use. Some users reported that this issue would most often occur when copying/creating and saving multiple specification groups in rapid succession. The cause of this issue is, at the time of this build’s release, unknown. To reduce the possibility of this issue occurring, an additional check has been placed into the Data Access interface in Toolbox, to ensure the data is not deleted unintentionally during software use.
