Recommended System Requirements for Microvellum Toolbox
Microvellum Toolbox runs on either BricsCAD or AutoCAD. System requirements vary slightly depending on which CAD platform you use. To ensure the best performance, we recommend the following:
Supported Operating Systems
  1. Windows 10
  2. Windows 11
Processor (CPU)
  1. Minimum: Intel Core i5 or AMD Ryzen 5
  2. Recommended: Intel Core i7 / i9 or AMD Ryzen 7 / 9
Additional Notes:
  1. Prioritize high single-thread performance.
  2. More cores improve rendering and heavy multithreaded tasks.
  3. Workstation CPUs (Intel Xeon, AMD Threadripper) are best for large or complex projects.
Memory (RAM)
  1. Minimum: 8 GB
  2. Recommended: 16 GB or more
  3. Use multi-channel memory (at least one module per channel) for improved performance.
Storage
  1. Minimum: ~3 GB for Toolbox + CAD installation
  2. Recommended: SSD (SATA III or PCI-E NVMe) for system and software
  3. HDDs may be used for non-critical data storage
Display & Graphics
  1. Minimum: Full HD (1920×1080) True Color display with a graphics card that has 4 GB VRAM
  2. Recommended: Dual displays with a dedicated GPU that has 8 GB VRAM
Additional Notes:
  1. Mid-range gaming GPUs (NVIDIA GeForce, AMD Radeon) are recommended.
  2. Always install the latest drivers.
  3. For large models, parametric assemblies, or point clouds, enable High Performance graphics.
  4. CAD Platform Considerations
BricsCAD V25
  1. Uses the same hardware requirements listed above.
  2. Optimized for modern GPUs and multi-core CPUs.
AutoCAD (2024 /2025/2026)
  1. Minimum requirements are generally lower, but performance gains are noticeable with higher-end CPUs and GPUs.
  2. Autodesk recommends 16 GB RAM and 8 GB VRAM for 3D modeling.
  3. Network licensing may require additional configuration.
For the best experience with either platform, we recommend:
  1. Windows 11, Intel i7 or AMD Ryzen 7, 16 GB+ RAM, SSD hard drive, and an 8 GB+ GPU with dual displays.
    • Toolbox Recommended Workstations
      This article provides a list of laptop and desktop workstations with the performance and power needed to run Microvellum Toolbox and similar applications. All of these machines meet or exceed our System Requirements for Toolbox. See What to Look for ...
    • What to Look for in a New Workstation for Toolbox & AutoCAD
      When you need to run a program like Toolbox or AutoCAD®, there are many factors to consider when selecting your new desktop or laptop workstation. Not only are these programs robust on their own, but cabinet designers often have peripheral programs ...
    • Microvellum Server System Requirements
      These are the minimum estimated system requirements to run Microvellum Server. Individual situations may vary based on your specific needs and the amount of SQL data stored. This article lists the system requirements for Microvellum Server. For SQL ...
    • Toolbox Release Notes: 2020-2025
      This document will catalog all Microvellum Toolbox software builds that were released in the years of 2020-2025. This encompasses builds 20.1.0203.641 to 25.1.1204.641 (current). Year of 2025 This section catalogs all Microvellum Toolbox software ...
    • Recommended System Configuration for Microvellum Production
      These system requirements include recommendations for Microvellum Production Operating System (64 bit):  Windows 11 Windows 10 Windows 32-bit is not supported. Processor: Minimum: 2.5-2.9 gigahertz (GHz) or faster processor Preferred: 3.0+ gigahertz ...
    • Toolbox Release Notes | Build 25.1.1218.641
      The following release notes apply to Toolbox build 25.1.1218.641 Part Properties Fixes A handful of issues centered around the Part Properties interface have been resolved: The Reference for Measurement tool in the interface has been fully removed ...
    • Transferring Global Variables to a new Library
      This article will explain the process of transferring customized Global Variables from your current library to a new installation of the Microvellum Foundation Library. The G! Workbook The Foundation Library contains all standard and custom data in ...
    • Microvellum Foundation Library Release Notes | Build 25.1121
      The following release notes apply to the Microvellum Foundation Library build 25.1121. Additions Added the new product, Master Island End Cabinet, to the Master Cabinets FF product category. Added the Nesting Optimization Report Select Processing ...
    • Toolbox Release Notes | Build 25.1.1204.641
      The following release notes apply to Toolbox build 25.1.1204.641 Toolbox Login Screen Update Fig. 1: The updated Toolbox Login interface. The Toolbox Login interface has had several changes applied to it to enhance its usability and allow for greater ...
    • Toolbox Release Notes | Build 25.1.1120.641
      The following release notes apply to Toolbox build 25.1.1120.641 Mouse Wheel Fix There was a reported issue in certain interfaces (such as report groups) in which hovering over a dropdown menu (such as Output Type) would result in the options within ...
