Understanding Base Points
Base points are used as a reference point when locating a part within a product.
All parts in Microvellum are referenced using rectangular boxes. Parts consist of 8 points and 6 faces. Faces 1 through 4 are the part’s edges and faces 5 and 6 are the part’s flat surfaces. Parts can be rotated in the X, Y, and Z axes. They can also be placed at any point in the X, Y, and Z axes. To place a part, a base point (1 - 8) will be required. In the image below, the part has a rotation of X = 0, Y = 0, and Z = 0 (0, 0, 0). This rotation shows points 2, 4, 6, and 8 on the visible (upside) face. Points 1, 3, 5, and 7 are on the nonvisible (downside) face. Also shown in the image below are the edgeband edges: Edgeband Width 1 (EBW 1) and Edgeband Length 2 (EBL 2). Edges not seen: Edgeband Width 2 (EBW 2) and Edgeband Length 1 (EBW 1). When this rotation is used, EBL 2 will reference the front of the cabinet.
Parts with a 0, 0, 0 rotation are commonly used for cabinet bottoms, tops, stretchers, and countertop decks. Base points 1, 3, 5, and 7 will locate the part from the bottom up. Base points 2, 4, 6, 8 will locate the part from the top down. For example, a cabinet bottom would use an odd number for its base point, while a top would use an even number for its base point.
The next image shows a part with a rotation of 0, -90, 0 (X, Y, Z). This rotation is commonly used for cabinet sides, and vertical divisions/partitions.
Even-numbered base points would locate the part from the left working right. Odd-numbered base points would locate the part from the right working left. For example, a left side would use an even-numbered base point, while a right side would use an odd-numbered base point.
The next image illustrates how cabinet sides, a top, and a bottom would be oriented.
The image below shows a part with a rotation of 0, -90, 90. This rotation is commonly used for cabinet backs, doors, and drawer fronts (vertical grain).
Even-numbered base points would locate the part from the front working backward. Odd-numbered base points would locate the part from the back working forward. For example, a door or a drawer front would have an odd-numbered base point so it would sit proud of the cabinet face.
The next image shows a part with a rotation of 90, 0, 0. This rotation is commonly used for drawer fronts (horizontal grain), drawer box fronts and backs, shelf edges, toe kick faces, and backsplashes.
The image below shows a part with a rotation of 90, 0, 90. This rotation is commonly used for drawer box sides, drawer divisions (between 2 drawers), toe kick sleepers, and end splashes.
Even-numbered base points would locate the part from the right working left. Odd-numbered base points would locate the part from the left working right. For example, a left drawer box side would use an odd-numbered base point, while a right drawer box side would use an even-numbered base point.
This next image shows the X, Y, and Z axes and how parts are typically located within the drawing environment. Notice that products extend forward in the -Y-axis. An easy way to think of this is to envision the X-axis as the face of a wall; parts located in the +Y would extend into the wall, and parts found in the -Y would extend away from the wall.
