Understanding Drawing Tabs
Located at the bottom of the drawing area are tabs that allow you to switch between the Model tab and other layout tabs.
  1. While working in the drawing environment, you will need to have the Model tab selected.
  2. Selecting any other tab will bring you to a layout tab.
Anytime you are drawing or modifying objects, you should be in the model tab. When you are ready to print, you can switch to one of the Layout tabs available. Toolbox default drawing templates have many different layout tabs available that represent different paper sizes. Right-clicking on any tab will display the drawing tab context menu that will allow performing many types of actions.  If you have many tabs, you can use the arrow buttons next to tabs to scroll through all the tabs in the drawing.
Drawing Tabs Context Menu
New Layout
Creates a new layout tab from scratch.
From Template...
Creates a new layout tab from a selected drawing template (DWT file). After selecting a drawing template file, a list box with the available layout tabs will be available for you to select from to import into the existing drawing.
Delete
Deletes the selected layout tab. You cannot delete the Model tab.
Rename
Rename the selected layout tab. You cannot rename the Model tab.
Move or Copy
This menu item will allow you to Copy an existing layout. After selecting the menu item, a dialog window will appear. Select the layout that you would like to copy and then select the Create a Copy checkbox. Then select the OK button. The selected layout will be copied. If you wish to move the tabs, it is better to left-click and drag the tab while inside the drawing environment. You cannot move or copy the Model tab.
Select All Layouts
Selects all the layout tabs in the drawing. If you right-click on the tabs again after using this option, a Publish Selected layouts menu item will be available in the context menu.
Publish Selected Layouts
If more than one layout is selected, the Publish Selected Layouts menu item will be available in the context menu. Selecting this menu item will display the Publish window and allow you to plot or output multiple layouts at the same time.
Activate Previous Layout
Will switch the drawing to the previously selected layout tab.
Activate Model Tab
Will switch the drawing to the Model tab.
Page Setup Manager
Displays the Page Setup Manager window.
Plot
Prints out the selected layout tab. It is recommended to set up the layouts in the page setup manager before plotting.
Import Layout as Sheet
This menu item is unavailable.
Export Layout to Model
Export the current layout as a drawing file that you can open in the model space environment. You will be asked for an export location on your local computer to create the layout drawing.
Dock Above Status Bar
The options are to dock above or in line with the status bar.
