The articles in this section of the Knowledge Base involve Text Formatting for display in your reports. To learn more about Text Formatting and how to access this section within the Report Designer, see Understanding Text Formatting in the Report Designer. This article focuses on the Number Format tab of the Text Formatting window.
It is recommended to use the Numeric Format type to display numeric values. Below is a report with the General Format type applied:
Product |
ProductID |
CategoryID |
UnitPrice |
1 Door Base |
1 |
1 |
50 |
2 Door Base |
2 |
1 |
75 |
1 Door Upper |
3 |
2 |
50 |
2 Door Upper |
4 |
2 |
75 |
1 Door Diagonal Corner Base |
5 |
3 |
75 |
To change the above numeric values from the General Format to the Numeric Format, select the text components that contain references to the relevant data columns and click the button of the Text Format property. In the Text Format window, select the Number tab and define the settings.
Product |
ProductID |
CategoryID |
UnitPrice |
1 Door Base |
1.00 |
1.00 |
50.00 |
2 Door Base |
2.00 |
1.00 |
75.00 |
1 Door Upper |
3.00 |
2.00 |
50.00 |
2 Door Upper |
4.00 |
2.00 |
75.00 |
5.00 |
3.00 |
75.00 |
There are disadvantages to both cases. To use local settings, you should edit formats of the operating system. For the second option, when one parameter needs to be changed, you should adjust others as well.
There is a third method of determining the format. You can change any parameter format using the local settings. First, set the flag next to the parameter and then set its value.
Thus, for columns ProductID and CategoryID, we change only the number of digits in the fractional part.
Product |
ProductID |
CategoryID |
UnitPrice |
1 Door Base |
1.0 |
1.0 |
50.00 |
2 Door Base |
2.0 |
1.0 |
75.00 |
1 Door Upper |
3.0 |
2.0 |
50.00 |
2 Door Upper |
4.0 |
2.0 |
75.00 |
5.0 |
3.0 |
75.00 |
