Adding vaulted ceiling to walls [issues]
I am adding vaulted ceilings to walls. I am selecting the proper measurements and the direction of the vault is the wrong way. The opposite wall is correct and using the exact same dimenions. This is probably due to drawing the walls left to right. When I draw the walls right to left, the dimensions and everything is flipped so that doesnt work either. Not reall sure how to change this but would be great to figure out.
