Copy a "Product" or a "Vertical"
I learned from  my use of "EPB" that every line segment created is to have its own/separate "Vertical". I believe the reason is: if one "Vertical" was used for the whole die wall being drawn, eventually there would be conflicts within the "Data".
Does that same philosophy hold when copying a product I.E. upper cab ten times in a job layout and making modifications to them on an individual basis?
