I have attached a quick design of a benchtop & Shelves with timber grain added and you can see that the waterfall legs have the grain running vertically, but the top has the grain running fron to back instead of left to right. This also happens as per attached picture in shelving and other items. If you have the grain set to Length in Part Properties or when you set up the material with graining direction, why they don't grain correctly in the drawing. Or is there an easy way to change this on the drawing that i don't know about?
