How To Bring Popup Windows Come To Foreground
We just setup new workstations running Microvellum build 24.1.1030.641 on Windows 11, performance is significantly improved but there are some issues coming up. One frustrating thing I have noticed that the popup windows that come up when processing a job do not come to the foreground or even flash on the taskbar indicating that they need attention. The first job I processed I couldn't believe how long it was taking, it wasn't until I hovered over the MV icon on the taskbar that I realized I needed to acknowledge a popup before proceeding. We ran the same version of MV on our previous workstations, which ran windows 10 and this was not an issue. While all popups that come up during processing exhibit this behavior there are other MV prompts which do come to the foreground on their own so it is not a behavior consistent throughout the application. I'm not sure if I should be looking for a Windows setting or a MV setting to change this behavior, hopefully someone with deeper knowledge can point me in the right direction.
