Lock strikes
Hello
I need some help, running foundation library 23_1010, in the material wizard, are the lock strikes that are listed under partition strike used for the cabinets also?
If not where do i find the strikes for cabinets?
How do i add machining tokens to those?
The strike i need to use is in the library, but has no machine tokens and I'm not exactly sure where to choose the right strike from, because in the hardware wizard there is only partitions strikes, cant find lock strikes to choose from.
thanks
