Lookup table for section cad blocks?
I am designing a display case and I am using a lookup table to determine the shelf depth based on the overall depth of the display case.  I need to figure out how to draw the appropriate cross section for the shelf supports (KV 180) based on the depth as well.
I would like to add a column in the lookup table with the appropriate cad file for the related depth.  If I do this, what would the formula look like to reference it?  I assume a vlookup function based on depth similar the bracket length is setup, but how do I fit that into the context needed to tells Microvellum to draw the block i.e. using the "drawblock" prompt in the cross section instructions?
Is this possible?  If not, I may need to get creative with some if/then statements...
