I'm having an issue with the scaling of my product/item number. When I was putting in a cabinet I was getting a ton of different scales for my dimensions and product/item numbers *see attached* and it was a long process to go and manually change the scale of everything to the scale I needed. I went to toolbox setup - AutoCAD - unchecked the box that says use annotative scaling *see attached* and it fixed the issue of all my dimensions and product/item numbers coming in with a ton of scales. However, now my product/item number is super small *see attached*. How could I fix that?
