Product prompts being overridden
Hello again,
I have this problem that is driving me slightly crazy.
When changing product variable from the Product Prompts screen, certain values get overridden (from a formula to a hard coded value).
I think this has something to do with the product calculator, but i have no calculator assigned to this particular prompt:
The Calculated Width for panel #5 prompt should read from either Panel 6 Width-Rear or Panel 5 With-Parse, depending on another prompt value.
Does anyone have any further insight into how the calculator works? I have a hunch that Prompt Names (not defined names) may have some influence.
