Room Name Different Drawing File
How to fix Rooms with different Drawing name?
I created new room but when I open it the drawing name is different, the drawing file is same as the other Room name and there is already units in it same as the other. I'm afraid if I will delete the units in this room the units will delete as well in other room. ( I remember while opening the room first time, there is notification that I should pick a drawing, I tick a file drawing named Laundry). maybe that's the reason.
