Tool Overide
I am trying to force our machine to use a 2 wing compression cutter (Tool3) instead of the default tool (tool2).
In edit material I have inserted T3 F18000 under coded however it does not make any difference.
On the sheet stock report it does show up as the above code.
Tool 3 is set up in the tool file as default Pocketing / SMA Router(s) so I am wondering if this makes a difference.
You help would be appreciated.
Cheers,
Trevor
