Work order part sorting
In a recent build, part sorting in the work order window has been broken (it worked in the past)
In split flow processing, we send various parts to different processing stations within the same work order. Example we would sort by say Material Name ASC, Part Name ASC, etc.... When you sort by the second column header, it drops the first sort order. So within 16mm_White_2S_Mel, if it were the second sort, we might get the following on our first sort (Part Name ASC):
Left Drawer Side
Left Drawer Side
Divider
Left Drawer Side
Is this a known issue in recent builds?
