PDFIMPORT Command
PDFIMPORT Command
Imports the objects in a PDF file or an attached PDF underlay from the command line.
Options are provided for selecting either a PDF underlay or for specifying a file.
  1. File - Opens a standard file selection dialog box, in which you can specify a PDF file. If the FILEDIA system variable is changed from 1 to 0, the dialog box is replaced by a command line prompt to enter the file name.
    1. Enter Page Number - Enter a page number. For a list of pages, enter ?.
    2. Enter Page(s) to List <*> - Lists the pages available in the PDF file in a separate text window.
    3. Insertion Point - Specifies the insertion point for the PDF file.
    4. Scale Factor - Specifies the scale factor of the imported PDF data and the scale factor units.
    5. Importing a page from a PDF file does not use the setting of the INSUNITS system variable.
    6. Rotation - Specifies the rotation angle of the imported PDF data.
  2. Select PDF Underlay - Imports part or all of an attached PDF underlay as AutoCAD objects. The following options are displayed.
    1. Specify first corner, Specify opposite corner - Prompts for the diagonal corners of a rectangular crossing area. Any objects crossing the specified area are imported.
    2. Polygonal - Prompts for a polygonal crossing area defined by at least three points to specify the objects to be imported.
    3. All - Selects all objects within the selected PDF underlay to be imported.
    4. Settings - Opens the PDF Import Settings dialog box.
    5. Keep, Detach or Unload PDF underlay? - Determines what to do with the selected PDF underlay after importing the specified objects. The Keep option leaves the PDF underlay unchanged; the Detach option removes the PDF underlay; and the Unload option temporarily hides the attached PDF.
Powered by  AutoCAD ®
