Render Materials Missing Layer Information (Reference)
As of build 15.6.1806, the Microvellum Apply Materials screen contains a column for the AutoCAD Layer Name and revised controls. The purpose of this article is to provide a reference for commands and controls on the Apply Materials screen.
See Render Materials Missing Layer Information (Overview) in the Microvellum Knowledge Network for a reference article explaining the commands and control options of the current Apply Materials screen.
You access the Apply Materials screen by clicking the Change Material button from the Camera command group on the Toolbox screen.
Fig. 1 – Apply Materials Screen
Assigning Materials to Layers
The materials are mapped or linked to the AutoCAD layers by opening the Apply Materials screen, highlighting the row containing the Item Name and AutoCAD Layer Name, then clicking a material on the left side of the screen and clicking the button at the top of the screen, “Apply Material to Layer” (with the checkmark icon).
In the examples below, the default material assigned the AutoCAD layer 3D_COUNTERTOP was “EVEREST.” We reassigned it to an “ash-olive” material with the method described in the preceding paragraph with the visual differences you see below.
Fig. 2 – Countertop Rendered with EVEREST Material Before Reassignment
Fig. 3 – Countertop Rendered with ASH-OLIVE Material After Reassignment
Apply Materials Interface Controls
Material Filters
Filter the materials displayed to help find the correct material using the dropdown boxes for Main Category and Sub Category.
Fig. 4 – Category Filters
Command Buttons
Use the command buttons to work with your rendering materials and layers.
Fig. 5 – Layer Command Buttons
  1. Use the button “Apply Material to Layer” to apply a selected material to a selected Item Name/Layer row.
  2. Use the button “Create New Layer” to add a layer to the list.
  3. Use the button “Delete Selected Layer” to remove a selected layer from the list.
  4. Use the button “Edit Selected Layer” to make revisions to a selected layer in the list.
Presets
Use the Load Preset box and controls to create combinations of rendering materials and AutoCAD layers. For example, you may create one preset in which the layer 3D_TALL_DOOR is linked to the rendering material “apple-tree.” A different preset may link that same layer to the material “ash-european.” When you load the first preset, all parts on the layer 3D_TALL_DOOR are rendered with the apple-tree material. When you load the second preset, all parts on that layer are rendered with the ash-european material.
Fig. 6 – Layer Command Buttons
Layer Types and Grouping
The Apply Materials screen contains two tabs, one for the layers and rendering materials that apply to various room components, and the other for the layers and rendering materials that apply to individual product parts.
The data in each of these tabs may be grouped by dragging a column heading to the dark grey area just below the tabs. For example, to see all the layers that are assigned to the material “aningeria,” drag the column header named Render Material Name to the dark grey area.
Fig. 7 – Item Name and AutoCAD Layer Name List Grouped by Render Material Name
You may drag multiple columns to group by multiple columns.
Check the box for each of the column header names included in the group definition to expand or contract each of the groups to customize how you display the data.
Drag a column header name from the dark grey area back to the desired location in the column header area to remove a group definition.
Each column header contains a dropdown box that you may use to filter what is displayed in the list below it without needing to scroll through long lists of items. For example, you may click to open the dropdown list for the Item Name and select Cabinet Doors, Cabinet Door Rails, and Cabinet Door Stiles. The list is then modified to include only those items. The lists are unique to any given preset.
Fig. 8 – Layer Command Buttons
Purge Unused Materials
Some of our users are accustomed to entering rendering materials at the AutoCAD command line. If you enter materials in this way, you will eventually have a large number of materials in the drawing that is not used. Checking this box purges those materials from the drawing.
Fig. 9 – Purge Unused Materials Checkbox
    • Render Materials Missing Layer Information (Overview)
      As of build 15.6.1806, the Microvellum Apply Material screen contains a column for the AutoCAD Layer Name. The purpose of this article is to provide an overview of the Apply Materials screen. This new column makes it possible to set up rendering ...
    • Applying Materials
      Applying MaterialsThe materials for a drawing can be changed using the Apply Materials interface. To access the interface, click on the Visual Style menu icon the tool strip, and then click on the Change Materials icon. The Apply Materials interface ...
    • Add New Rendering Materials in Toolbox
      Rendering materials are customizable. As you can see in the screenshot below, the rendering materials are split into Main and Sub Categories to categorize the materials for manageability.  The material categories with the materials they contain are ...
    • About Organizing Render Materials
      Copy materials to different libraries to create your own organization. About Materials Libraries The Toolbox render material library, with more than 700 materials and 1000 textures, is included with the product. You can copy Toolbox render materials ...
    • Creating and Modifying Materials
      A material is defined by a number of properties. The available properties depend on the selected material type. You cannot modify the materials in the Toolbox materials library, but you can use them as a basis for new materials. The Materials Editor ...
    • Microvellum Processing Center Application
      The standalone Processing Center application provides shop-floor tools for managing and executing manufacturing data generated from Microvellum projects. It enables users to: Print part labels View and print reports Create and re-create manufacturing ...
    • Microvellum Release Notes | Build 25.2.0213.641
      The following release notes apply to Microvellum build 25.2.0213.641 File Name Fix An issue was occurring when processing work orders with the Create Sequential File Names setting enabled. When the setting was enabled, a work order being processed ...
    • Microvellum Release Notes | Build 25.2.0206.641
      The following release notes apply to Microvellum build 25.2.0206.641. Item Number Fix An issue was reported regarding item numbers in composite drawings. Users who processed work orders with multiple products reported that the item numbers would ...
