STRETCH Command
STRETCH Command
Stretches objects crossed by a selection window or polygon.
Objects that are partially enclosed by a crossing window are stretched. Objects that are completely enclosed within the crossing window, or that are selected individually, are moved rather than stretched.
Select Objects
Specifies the portion of the object that you want to stretch. Use the cpolygon option or the crossing object selection method. Press Etner when the selection is complete.
STRETCH moves only the vertices and endpoints that lie inside the crossing selection, leaving those outside unchanged. STRETCH does not modify 3D solids, polyline width, tangent, or curve-fitting information.
Base Point
Specifies the base point from which the offset for the stretch is calculated. This base point can be outside the area being stretched.
Second Point
Specifies a second point that defines the distance and direction of the stretch. The distance and direction of this point from the base point defines how far and in what direction the selected portions of the object will be stretched.
Use First Point as Displacement
Specifies that the stretch distance and direction will be based on the distance and direction of the base point you specified from the 0, 0, 0 coordinates in the drawing.
Displacement
Specifies the relative distance and direction of the stretch.
  1. To set a displacement based on the relative distance from the current location, enter distances in X, Y, Z format. For example, enter 5, 4, 0 to stretch the selection to a point that is 5 units along the X axis and 4 units along the Y axis from the original point.
  2. To set the displacement based on the distance and direction from the 0, 0, 0 coordinates in the drawing, click a location in the drawing area. For example, click a point at 1, 2, 0 to stretch the selection to a point that is 1 unit along the X axis and 2 units along the Y axis from its current location.
Powered by AutoCAD®
