The following release notes apply to Toolbox, Build 20.1.0617.641
Projects
Additions:
- Added the ability to increment item numbers by the project or the room. The setting can be controlled in the options page,
under the “Item Number Setup” section. Learn more.
Processing
Resolutions:
- Resolved an issue with the C.R. Onsrud Series S
post-processor that created duplicate drilling on parts.
- Resolved an issue where the Ardis Parts file
station would not produce the part image according to the file type.
Work Orders
Additions:
- Added the ability to add/modify sheet sizes and delete batches in the work order. Learn more.
- Added a drop-down of previously used names in the Work Order Creation UI. Learn more.
Modifications:
- Modified the Edit Existing Work Order UI to cause the
search text box fields to have focus when the UI is first opened.
- Modified the work Order name field to allow it
to be edited when creating a work order.
- Modified the Work Order Creation UI to provide
more details about the products that are being processed (Example, “Product 2
out of 25 – Collecting Parts…”)
Engineering
Resolutions:
- Resolved an issue where accessing certain
subassemblies in the Part Properties UI would cause Toolbox to crash.
- Resolved an issue where the Part Properties
interface could hard-lock incorrect values in for the X, Y, and Z origin.
- Resolved an issue resulting in Toolbox crashing
when the subassembly did not have any parts with the Draw3Dbox drawing token in
it or had just negative materials.
- Resolved an issue where reloading the same
subassembly within the Part Properties UI and not saving the subassembly would
produce an error.
View the Release Notes from Previous Builds
