Toolbox Release Notes | Build 23.1.0811.641
The following Release Notes apply to Toolbox build 23.1.0811.641
UI Overhauls
Fixes
Before
After
Figure 1: "Add Part" loop error message.
Figure 2: "Add Part" message fix.
  1. Users reported an issue wherein the software would error out into an endless loop when cancelling out of the “Add Part” option after getting a “non-perpendicular USC X and Y” error. This issue has been resolved- the error resulting in the loop has been removed, and the message has been updated to offer greater specificity.
  1. Another error in the "Add Part" option was reported, wherein the "Preview" option being clicked before selecting a UCS position would result in an unhandled exception error. This has been resolved- the option to preview has been greyed out until a UCS position has been selected.
Figure 3: 900 Tool error.
  1. There was a noted issue within the Toolfiles, under the "Multi-Pass Tool Info" settings, wherein from switching from the "Multiple Tools" or "Incremental Step" options to the "Step" option while selecting a 900 Tool would cause an unhandled exception error. This issue has been resolved.
Figure 4: UI Shrinkage.
  1. Within the Toolfiles, users reported an issue wherein buttons on the UI would disappear due to the UI maxing out the size to move them offscreen, leading to shrinkage of buttons that left them unable to select certain options. This issue has been resolved- the UI now has a minimum and maximum size to ensure the options are always available for selection.
Figure 5: Incorrect door swing and sink lines.
Figure 6: Corrected door swing and sink lines, post redraw.
  1. Users reported an issue when working with 2D wall plans, wherein sink and door swing lines would appear in the incorrect location when adding in a "ProductAngle" prompt via the spreadsheet, rather than the interface. This incorrect angling would persist unless the 2D wall plan was redrawn. This issue has been resolved- utilizing the spreadsheet for this prompt should function properly within the plan without requiring a redraw.
Modifications
Figure 7: Visual overhaul for "Import" settings.
  1. UI options such as the "Import Files" or "Import Onscreen Data" options have been visually updated to match with the rest of the Toolbox UI. Spacing, border and heading coloration, as well as language specificity and available clickable options have been updated.
Figure 8: "Wall Setup" and "Product Drawing Setup" UI adjustments.
  1. Within "Toolbox Setup", the options to adjust wall dimensions were noted to have insufficient layout within the UI: within "Wall Setup" the "Default Wall thickness" entry field was deemed to be too close to top of the window, and under "Product Drawing Setup", The "Close" and "OK" buttons were noted to be too close to the right edge of the window, and the window needed changes to the option borders to be more visually consistent. The UI has been updated to apply these changes.
Figure 9: "Show Edge" update for efficiency.
  1. The process within "Part Properties" for the "Show Edge" option was deemed inefficient for workflows, due to the need to reselect the part when attempting to modify or enter specifications for it within the UI, even if a part is already selected. As such, the setting has been modified to automatically enter in the properties of the selected edge of a product.
Figure 10: "Select Wall" issue.
  1. Options that lead to errors or which failed to do anything substantial without first enabling other options, such as "Select Wall" being available for selection during "Update Selected Wall" have been greyed out.
Figure 11: Misspellings of "Entities".
  1. It was noted that there was a misspelling of the word "entities" in the "Modify Products" section. This misspell has been corrected.
