Toolbox BSB is Now Available
Toolbox BSB, a version of Toolbox bundled with BricsCAD Pro, is now available for download in the Microvellum Portal. It includes the same engineering and manufacturing capabilities you rely on—now powered by a CAD platform that delivers speed, flexibility, and full DWG compatibility without the need for an AutoCAD license.
You can start a trial directly from the Portal—no requests, no delays. It’s a great way to explore the BricsCAD environment and see how it works with Toolbox.
The Portal has also been updated to support automated conversions from Toolbox OEM to Toolbox BSB. If you’re using Toolbox OEM, you can now make the switch on your own, right from the Portal. If you're not using Toolbox OEM, please contact your account manager to get started with your trial of Toolbox BSB!
Helpful Links:
