FAQ: Toolbox BSB (BricsCAD)
This FAQ addresses common questions about Toolbox BSB (BricsCAD), including what it is, how it differs from Toolbox OEM, and what users need to know about conversion, licensing, and core features.
General Overview
  1. What is BricsCAD?
    1. BricsCAD is a powerful CAD software that supports both 2D drafting and 3D modeling using the industry-standard DWG file format. BricsCAD offers Microvellum users a compatible CAD engine that works seamlessly with Toolbox. BricsCAD uses the same familiar CAD commands and tools you’re already accustomed to, so there’s no need to relearn the basics. Whether you're drafting, editing, or managing layers, the core functionality mirrors what you already know, eliminating the typical learning curve that comes with switching CAD platforms. This continuity ensures a smooth and easy transition, allowing you to stay productive and confident as you move into the BricsCAD environment.
    2. Want to see Toolbox BSB in action? Explore our First Look video series showcasing Toolbox BSB (BricsCAD).
  2. What motivated Microvellum to create the integration with BricsCAD?
    1. We wanted to expand the CAD options available for Toolbox and create more opportunities to innovate. BricsCAD offers full DWG compatibility, runs Toolbox as you would expect, and provides a familiar experience for CAD users. This integration gives us the flexibility to evolve the Toolbox platform in new ways, while continuing to deliver the performance and functionality users count on.
  3. Will Microvellum continue to support Toolbox OEM?
    1. No, Microvellum will not continue long-term support for the Toolbox OEM version of Toolbox. Support will be phased out on July 20, 2025. After that date, updates and full installations will no longer be available. Going forward, users will need to transition to either Toolbox BSB (BricsCAD) or Toolbox AC, depending on their preferred CAD environment.
  4. What is Toolbox BSB (BricsCAD)?
    1. Toolbox BSB (BricsCAD) is Microvellum’s new bundled solution that replaces Toolbox OEM. It includes BricsCAD Pro and delivers the full functionality of BricsCAD Pro alongside Microvellum Toolbox—all packaged together in a single, streamlined installation.
  5. What is the release date for Toolbox BSB (BricsCAD)?
    1. The scheduled release date for Toolbox BSB (BricsCAD) is July 21, 2025.
  6. How does the transition from Toolbox OEM to Toolbox BSB (BricsCAD) work?
    1. Transitioning from Toolbox OEM to Toolbox BSB is a flexible, guided process that allows you to evaluate the new environment, prepare your team, and convert when you’re ready, all while ensuring minimal disruption to your work.
    2. Start with a 45-Day Toolbox BSB Trial
    3. You can begin with a 45-day Toolbox BSB trial, which will be available for all Toolbox OEM users to activate from the Microvellum Portal. This gives you the opportunity to:
      1. Explore the BricsCAD environment using your own projects and workflows.
      2. Get familiar with the interface, tools, and performance.
      3. Evaluate how Toolbox BSB fits your team’s needs.
      4. The trial period allows you to build confidence in the platform before initiating the conversion.
      5. If you need more time, you can extend your trial by 45 days within the Microvellum Portal
    1. Use Video-based Education to Get Familiar with BricsCAD
      1. To support your evaluation, Microvellum provides training resources specifically for Toolbox BSB through the INNERGY PeAk learning platform:
      2. A Toolbox BSB (BricsCAD) training plan featuring 15 Microvellum-produced videos tailored to help users transition from your existing CAD workflows.
      3. Access to over 100 curated Bricsys training videos, covering BricsCAD fundamentals, navigation, and productivity workflows.
      4. These resources are designed to help your team onboard effectively and build familiarity with the BricsCAD environment prior to conversion.
    2. Convert When You're Ready
      1. Once your team is comfortable in the BricsCAD environment and you’re ready to move forward:
      2. Log into the Microvellum Portal and look for the option to convert your Toolbox BSB license.
      3. If you’re not a Portal Admin, you’ll need to contact someone who is.
      4. Admins will be guided through an agreement form and asked to review the updated EULA.
      5. Once the EULA is accepted, the license becomes active.
      6. License details, including credentials and download links, will appear in the Portal.
      7. A confirmation will be created, along with a link to helpful setup resources.
    3. This automated, portal-guided process is designed to make your transition to Toolbox BSB as simple and efficient as possible, empowering you to evaluate, train, and convert at your own pace with full support every step of the way.
  7. If I already own a BricsCAD license, is there an installation of Toolbox available outside of the BSB?
    1. Currently, installing Toolbox alongside an existing BricsCAD installation—purchased directly from Bricsys—is not supported. This integration is planned for a future release.
  8. Is BricsCAD considered a lower-tier CAD platform compared to other CAD software?
    1. Not at all. BricsCAD is a powerful, professional-grade CAD platform that fully supports the DWG file format and delivers a robust environment for both 2D drafting and 3D modeling. It includes many of the same features found in leading CAD solutions, along with unique tools and added flexibility that make it a strong, future-ready alternative.
Licensing & Pricing
  1. Are there costs associated with converting to Toolbox BSB?
    1. There are no out-of-pocket costs to convert your existing Toolbox OEM licenses to Toolbox BSB (BricsCAD), provided you complete the conversion within the next 18 months. Your current annual User License Maintenance (ULM) and OEM maintenance fees—based on your existing payment cycle—will be applied toward your Toolbox BSB subscription, making the conversion cost-neutral for your existing licenses. If you add new users or increase your license count, additional charges will apply. After the 18-month window, this cost-neutral conversion offer may no longer be available, and price increases may apply when converting to Toolbox BSB.
  2. If I convert to Toolbox BSB, will I also transition to a subscription pricing model?
    1. When converting to Toolbox BSB, any software modules and licenses you previously purchased under a perpetual model will remain owned by you. The only component that will transition to a subscription is the CAD platform—referred to as the Toolbox BSB license—which will be provided at no additional cost.
  3. How do I obtain a Toolbox BSB license?
    1. You can obtain a 45-day trial or official Toolbox BSB license directly from the Microvellum Portal under the Account Management section.
    2. Step 1: Activate a 45-day trial to evaluate the BricsCAD platform. You'll receive instructions for downloading, installing, and accessing video-based training resources.
    3. Step 2: Convert your Toolbox OEM licenses. Review and accept the conversion terms, then download and activate your software. The process is streamlined and user-friendly, allowing you to get up and running quickly and efficiently.
  4. Are there trial versions of Toolbox BSB available?
    1. If you would like to begin exploring Toolbox BSB, a 45-day trial version of the software will be available within the Software Management area of the Microvellum Portal for all existing Toolbox OEM users on July 21st.
    2. The total allowed seats provided within the trial license should align with your total Toolbox OEM seats. This will ensure all current users will be able to explore the Toolbox BSB (BricsCAD) environment. To activate this trial, you must be a Portal Admin. If you currently use Toolbox AC and would like to evaluate Toolbox BSB (BricsCAD), you may request a trial from your Account Manager.
  5. Do I have to convert to Toolbox BSB (BricsCAD)?
    1. No, you are not required to convert to Toolbox BSB (BricsCAD). However, after July 20, 2025, Toolbox OEM will no longer receive updates, and installation files will no longer be available through the Microvellum Portal or from our team
    2. While your existing installation will continue to function as it always has, choosing not to convert comes with some risks:
      1. If you lose access to your current installation files, reinstalling may become difficult or impossible.
      2. You will no longer receive updates or new features, meaning you'll fall behind as Microvellum continues to enhance and expand its software offerings.
    3. Remaining on your current build is an option, but we encourage conversion to ensure continued access to improvements, support, and long-term stability.
  6. Does Toolbox BSB include access to BricsCAD Shape?
    1. No, Toolbox BSB does not provide access to BricsCAD Shape. However, Shape is a free product offered by Bricsys and can be downloaded separately from their website.
Training & Support
  1. Does Microvellum offer any services to assist with the transition from Toolbox OEM to Toolbox BSB? (BricsCAD)
    1. To support your transition from Toolbox OEM to Toolbox BSB (BricsCAD), we've curated over 7 hours of video content to guide you through a successful migration to the BricsCAD platform and made it available within the INNERGY PeAk LMS platform. This content is available free of charge. For personalized training or integration services, please contact your Account Manager.
  2. Does Microvellum provide BricsCAD support?
    1. Microvellum provides limited support for issues related to the BricsCAD platform. If a reported issue is determined to be BricsCAD-specific, we will submit the support request to BricsCAD’s Quality Assurance team on your behalf. While we do not control their resolution timeline, we will monitor the issue and provide updates through a future Toolbox BSB release once a fix is available.
  3. Does Microvellum University include a Toolbox BSB (BricsCAD) specific training plans?
    1. Yes. Microvellum University includes a dedicated Toolbox BSB (BricsCAD) training plan specifically designed for users transitioning from Toolbox OEM, including:
      1. 15 Microvellum-produced videos focused on helping users get familiar with the BricsCAD interface and how Toolbox BSB works within it.
      2. A curated collection of 100+ Bricsys training videos that cover core BricsCAD concepts and workflows.
  4. Together, these resources offer a complete onboarding experience, supporting users through both the technical differences and the real-world application of Toolbox BSB in BricsCAD.
Installation & Transition Process
  1. Can I have both Toolbox OEM and Toolbox BSB (BricsCAD) installed side-by-side for transitioning?
    1. Yes, Toolbox OEM and Toolbox BSB can be installed side-by-side on the same computer during your conversion. This allows you to evaluate Toolbox BSB using a trial license while maintaining access to your existing OEM version.
    2. While both versions can coexist, Microvellum recommends fully transitioning to either Toolbox AC or Toolbox BSB, as Toolbox OEM will no longer be supported after July 20, 2025 and it’s critical that all workstations accessing shared data use the same Microvellum version.
  2. What happens to my existing Toolbox OEM licenses after I transition to Toolbox BSB (BricsCAD)?
    1. Once you complete your official transition from Toolbox OEM to Toolbox BSB, your Toolbox OEM licenses will remain active indefinitely.
    2. However, Toolbox OEM, including all existing modules access, CAD functionality, etc. will be left behind in a plateaued state. This means Toolbox OEM will remain functional, is unmaintained, and at some point in the future, incompatibility will occur. Note: any new modules purchased will only be associated with Toolbox BSB.
  3. What is the best way to transition from Toolbox OEM to Toolbox BSB (BricsCAD) while minimizing disruption to projects?
    1. We recommend installing the latest build of Toolbox OEM and sandbox testing it before July 20 to ensure the changes between versions are limited to the Brics envrionment.
    2. The most effective way to transition from Toolbox OEM to Toolbox BSB (BricsCAD) is to start with a trial of Toolbox BSB. This allows your team to explore the BricsCAD environment hands-on while continuing work in your existing or sandbox environment until you're fully confident in the switch.
    3. Evaluate with Minimal Risk
      1. Begin by activating a trial license of Toolbox BSB. Use this time to:
      2. Explore the interface and functionality.
      3. Identify any key differences in workflow.
      4. Test how your current projects and product data operate within BricsCAD.
    4. Train with Targeted BricsCAD Lessons
      1. To accelerate your learning curve and minimize disruption:
      2. Leverage the BricsCAD lesson plans available in PeAk, a comprehensive library of over 100 videos (6+ hours) tailored for users choosing to make the switch from an existing CAD environment to BricsCAD.
      3. These lessons cover interface navigation, drawing tools, command usage, and best practices, everything you need to work confidently in BricsCAD.
    5. Enable Team Readiness
      1. While evaluating, help others in your company get familiar by:
      2. Sharing access to the trial software and video content.
      3. Encouraging hands-on practice with real or test projects.
      4. Reviewing key differences together as a group to build collective understanding.
    6. Convert When Confident
      1. Once your team is comfortable and aligned, proceed to convert your trial into active Toolbox BSB licenses. This approach ensures:
      2. A smooth, low-friction transition.
      3. Minimal downtime for your projects.
      4. Full confidence in your new BricsCAD-based environment.
  4. Do I have to finish my open projects before migrating from Toolbox OEM to Toolbox BSB (BricsCAD)?
    1. No, you do not have to finish your existing project(s) before migrating to Toolbox BSB (BricsCAD). You can simply install the software, open it, enter your License ID and Activation Password, select your configuration, and then open your existing project to continue working without interruption. Toolbox BSB is designed to be compatible with your current project data and workflow, allowing you to transition seamlessly without needing to recreate or convert your work.
  5. Who can help me if I need assistance with installing or migrating to Toolbox BSB?
    1. If you need help with your installation or migration, Microvellum’s Technical Support team is available to assist you. They can answer questions, help diagnose issues and provide guidance for installing Toolbox BSB and migrating from Toolbox OEM or Toolbox AC. Be sure to follow all the instructions provided to you as part of the migration step-by-step process—there’s also a quick video available to guide you. To get started, simply create a support case to let us know you need assistance.
Compatibility & Configuration
  1. Will all my existing Microvellum projects created in Toolbox OEM work in Toolbox BSB?
    1. Yes, all of your existing Microvellum projects created in Toolbox OEM will work in Toolbox BSB. This includes your projects, library data, databases, and other configuration files; everything functions as expected with no changes required.
  2. Does switching to Toolbox BSB (BricsCAD) require reconfiguring my Microvellum environment or templates?
    1. No, switching to BricsCAD does not require reconfiguring your Microvellum environment or templates. Your existing setup, including templates, configuration settings, and access to project data, will continue to work as it always has.
  3. Are there any CAD features that are unavailable or behave differently in Toolbox BSB (BricsCAD) when using Microvellum?
    1. Yes, while the core functionality of Microvellum Toolbox remains the same across platforms, there are a few platform-specific features that may be unavailable or behave differently in Toolbox BSB (BricsCAD). These differences are minor and do not affect Microvellum workflows. For most users, the transition is smooth and requires no changes to their workflow. Documentation is available on the Microvellum Community that outlines features that may function differently in BricsCAD.
  4. Can I migrate my CAD standards, layers, and blocks from Toolbox OEM to Toolbox BSB (BricsCAD)?
    1. Yes, you can migrate your CAD standards, layers, blocks, and other custom content from Toolbox OEM to BricsCAD. Since both platforms use the DWG file format, most of your templates, layer setups, block libraries, linetypes, and dimension styles are fully compatible and typically require no conversion, helping you maintain consistency with minimal setup.
  5. Are all Microvellum tokens and machining tools fully functional in the BricsCAD environment?
    1. Yes, all Microvellum tokens and machining tools are fully functional in the Toolbox BSB (BricsCAD) environment. The integration ensures that engineering, machining, and production workflows perform just as they do in Toolbox OEM. You can continue your work seamlessly without compromising functionality.
  6. Can I customize BricsCAD’s interface to match my existing workspace?
    1. Yes, you can customize BricsCAD’s interface to closely match your existing workspace. BricsCAD supports full workspace customization through its CUI (Customize User Interface) system. Even better, you can import your existing CUI files directly into BricsCAD, allowing you to migrate your toolbars, menus, keyboard shortcuts, and workspace layouts with minimal effort. This makes it easy to recreate a familiar environment and helps reduce the learning curve for teams transitioning to BricsCAD.
  7. Will Microvellum continue to support Toolbox OEM long term, or is Toolbox BSB (BricsCAD) replacing Toolbox OEM?
    1. While Microvellum will continue to support Toolbox AC, our development for Toolbox OEM will end on July 20, 2025. On that date, updates and access to full version installations of Toolbox OEM will no longer be accessible through the Microvellum Portal and will no longer be available for distribution.
  8. Will my Toolbox OEM dynamic blocks be compatible with Toolbox BSB and BricsCAD?
    1. Yes, with some important considerations. BricsCAD supports the DWG file format, so your existing dynamic blocks from Toolbox OEM, can be used in BricsCAD without needing conversion. However, if you modify dynamic blocks within BricsCAD, those changes may not be fully compatible when the drawing is opened again in your existing CAD software. This is due to differences in how the two platforms handle block definitions and edits.
    2. To ensure cross-platform consistency:
      1. Use blocks created in Toolbox OEM as-is within BricsCAD whenever possible.
      2. Avoid modifying dynamic blocks in BricsCAD if you intend to use those drawings in other CAD software later.
Performance & User Experience
  1. What are the system requirements for running Toolbox BSB (BricsCAD)?
    1. The system requirements for Toolbox BSB (BricsCAD) are similar to those for running Toolbox OEM. Here are the general guidelines:
      1. Minimum System Requirements
        1. Operating System: Windows 10 or Windows 11 (64-bit)
        2. Processor: Intel® Core™ i5 or equivalent
        3. Memory: 16 GB RAM
        4. Graphics: Dedicated GPU with 2 GB VRAM or higher (DirectX 11 compatible)
        5. Hard Drive: SSD with at least 20 GB free space
        6. Display: 1920 x 1080 resolution or higher
      2. Recommended System Requirements (for optimal performance)
        1. Processor: Intel® Core™ i7 or better
        2. Memory: 32 GB RAM
        3. Graphics: Dedicated GPU with 4 GB+ VRAM (NVIDIA or AMD, DirectX 12 support)
        4. Hard Drive: NVMe SSD
        5. Display: Dual monitors with high-resolution support (4K optional)
  2. What performance differences does BricsCAD offer?
    1. BricsCAD is built for speed and efficiency, especially when working with large or complex drawings. It opens and saves files quickly, runs smoothly on mid-range hardware, and includes smart tools like BLOCKIFY and Optimize to help clean up geometry and reduce file size. The interface is streamlined and customizable, making it easy to work the way you want. Plus, performance improvements are rolled out regularly, not just once a year, so things keep getting better over time.
  3. What kind of performance or stability can users expect when using BricsCAD with Microvellum?
    1. A lot of users say BricsCAD runs really well with Toolbox. It handles things like opening, saving, and regenerating drawings smoothly, and feels responsive when you're zooming, panning, or working with big DWG files. It’s also known for being solid and stable, even during long work sessions or when you have a large number of drawings open.
  4. How does the user interface of Toolbox BSB (BricsCAD) compare to Toolbox OEM for daily Microvellum tasks?
    1. The user interface of BricsCAD is very similar to Toolbox OEM, making it easy for Microvellum users to transition with minimal disruption. The layout, command structure, ribbon menus, and command line behave much like the existing CAD software, so users familiar with that environment will feel comfortable right away. For daily Microvellum tasks, like drawing, editing, and navigating the model space, BricsCAD provides a familiar and intuitive experience, allowing users to maintain their existing workflows without needing to relearn the interface.
  5. How difficult is it to learn BricsCAD after using my existing CAD software for years?
    1. For users who have been using an existing CAD software, learning BricsCAD is generally quick and straightforward. The two platforms share a very similar user interface, use the same DWG file format, and support nearly identical command structures. Most common commands, keyboard shortcuts, and drafting workflows carry over directly. While there may be minor differences in terminology or feature placement, the learning curve is minimal, and most users can become productive in BricsCAD within a short time, often within a few hours to a couple of days.
  6. Are there keyboard shortcut differences or UI layout changes I should expect in BricsCAD?
    1. Yes, there are some minor differences in keyboard shortcuts and UI layout between BricsCAD and your existing CAD software, but overall, the experience is very similar. Most commonly used commands and shortcuts work the same way, and BricsCAD’s interface closely mirrors what you’re used to, including the ribbon, command line, and tool palettes. However, some less frequently used shortcuts may differ, and certain UI elements might be arranged slightly differently. The good news is that BricsCAD allows users to create and customize their own keyboard shortcuts using the built-in Customize (CUI) interface. This means you can adjust the setup to match your personal preferences or replicate your current environment, making the transition smooth and efficient.
Warning
Toolbox BSB is not compatible with Windows Remote Desktop Service (RDS) environments. As such, if you happen to be using an RDS environment in your business, it is not recommended to attempt to install Toolbox BSB for use within it. This compatibility limitation does not apply to standard remote desktop connections made directly to a workstation.
File Format & Data Interoperability
  1. Does Toolbox BSB (BricsCAD) support the same imports/exports as Toolbox OEM?
    1. Not entirely. Toolbox BSB does not support all the same import/export formats as Toolbox OEM by default. On the other hand there are additional formats that Brics supports such as Sketchup.  However, Bricsys offers an optional add-on called Communicator for BricsCAD, which extends file interoperability to include formats like STEP, IGES, and other 3D file types, bringing it closer to existing capabilities. Documentation outlining the differences between Toolbox OEM’s import/export capability compared to Toolbox BSB (BricsCAD) is available on the Microvellum Community Knowledge Base.
    2. Currently, the Communicator add-on is not supported for use with Toolbox BSB, but compatibility is planned for a future release.   Many of these other applications also allow export in a .dwg format which can be opened in Brics.
Import & Export Capabilities
  1. How often is BricsCAD updated, and does that impact Microvellum stability?
    1. BricsCAD receives multiple updates throughout the year, including performance improvements, bug fixes, and new features. So far, in 2025, there have been 7 releases of BricsCAD. These updates do not impact the stability of Microvellum software—supported versions are thoroughly tested to ensure reliable, consistent performance with each release.
  2. Will Toolbox BSB get BricsCAD updates as soon as Bricsys releases them?
    1. Not right away. Since Toolbox is bundled with BricsCAD, we take a little extra time to test updates we receive and make sure everything works smoothly together. That means you might see a slight delay between when Bricsys releases an update and when it’s available through Toolbox BSB, but it’s all about making sure you have a stable, reliable experience.
  3. Does Model Documentation (VIEWBASE) work in BricsCAD?
    1. Yes, BricsCAD supports the VIEWBASE command and offers the same model documentation capabilities as you’re used to. The primary differences are in the interface, context menus, prompts, and UI behaviors may vary slightly. However, the core functionality for creating base views, projected views, sections, and details from 3D models is present. Users may need to adapt their workflow slightly to accommodate these UI differences, but BricsCAD fully supports the same detailing tools.
  4. Are the visual styles and shading options in BricsCAD comparable to those in my existing CAD software?
    1. Yes, BricsCAD offers similar view and shading styles to existing styles and options, including 2D wireframe, 3D wireframe, hidden, shaded, shaded with edges, realistic, and X-ray. These visual styles make it easy to view and interact with your models during drafting and design. While the presentation and rendering quality may differ slightly, the overall viewing experience is very familiar, allowing users to navigate and visualize their work in BricsCAD much like they currently do. Users have reported better performance with some of these additional visual styles as well.
  5. Can DWG files be used interchangeably between other CAD software and BricsCAD?
    1. Yes, DWG files are fully compatible with BricsCAD, and vice versa. Both platforms use the same native DWG file format, which means you can open, edit, and save drawings between them without conversion or loss of data. This ensures seamless collaboration and easy file sharing, regardless of whether a project was started in other CAD software or BricsCAD.
  6. How often is Microvellum’s QA team testing compatibility with BricsCAD?
    1. Microvellum’s QA team actively tests compatibility with BricsCAD regularly, especially during software updates and version releases. While the exact frequency may vary, testing is conducted as part of ongoing development cycles to ensure stability, performance, and full functionality of Toolbox AC and Toolbox BSB platforms. This continuous validation helps ensure that Toolbox works reliably in the BricsCAD environment.
Toolbox BSB, being based on BricsCAD Pro V25, is capable of importing or exporting (or both) the following file formats:
  1. PDF (Import, Export)
  2. 3D PDF (Export)
  3. DAE (Collada – Import, Export)
  4. 3DM (Rhino – Import, Export)
  5. LandXML (Import, Export)
  6. Civil 3D data (Import)
  7. SKP (SketchUp – Import)
  8. DGN (MicroStation – Import)
  9. DWF (Export)
  10. SVG (Export)
  11. FBX (Export)
  12. STL (Export)
Software Features & Functionality
  1. Are LISP routines available within Toolbox BSB (BricsCAD)?
    1. Yes. Toolbox BSB (BricsCAD) supports AutoLISP. This means you can load and run your existing .LSP routines directly within the BricsCAD environment. Most standard LISP routines will work without modification. However, if a routine relies on commands, functions, or external tools that are specific to your existing CAD software, you may need to make minor adjustments.
  2. Are Express Tools available in Toolbox BSB (BricsCAD)?
    1. Yes, BricsCAD Pro includes a set of Express Tools that offer added functionality for tasks such as layer management, text manipulation, block editing, and drawing cleanup. It's important to note that Express Tools and Lisp routines were not included in the Toolbox OEM.
Depending on your experience with other CAD software, these tools may be new to you, but they can significantly enhance your workflow, particularly for tasks like adding toolpaths to exploded text. BricsCAD’s Express Tools provide added functionality and are included as part of Toolbox BSB (BricsCAD) at no additional cost.
Customization
  1. How customizable is the BricsCAD interface, including layout, tools, and color settings?
    1. Yes! BricsCAD gives you a lot of control over how your workspace looks and works. You can customize toolbars, ribbons, menus, and even create your own workspaces for different tasks like drafting or modeling. Keyboard shortcuts and mouse buttons can be reassigned, too.
    2. If you're used to a specific setup, you can import your existing CUI files to bring over familiar tools and layouts.
    3. You can also change how things look—adjust colors for backgrounds, grips, crosshairs, and more. Light and dark themes are available, and you can tweak them even further if you like. Overall, BricsCAD makes it easy to build a workspace that feels just right for you.
User Concerns
  1. I just bought Toolbox OEM. Does this mean my investment is obsolete?
    1. No, your investment is not obsolete. You can continue using Toolbox OEM, and it will remain functional. You’ll also receive updates through July 20, 2025. After that date, no further updates or full installation files will be available, but your current installation will continue to work. Microvellum is transitioning to Toolbox BSB (BricsCAD) moving forward. When you're ready, you’ll have the option to convert to Toolbox BSB. A prorated subscription will be provided based on the time left on your current maintenance agreement, so you’re not losing value. In the meantime, we recommend activating the 45-day Toolbox BSB trial and reviewing the available training to prepare for the transition if or when you choose to make it.
  2. I use Toolbox AC, will I be impacted by the release of Toolbox BSB?
    1. If you're using Toolbox AC, you will not be impacted by the release of Toolbox BSB. There's no need to convert your license; Toolbox AC will continue to be supported and function as usual. Toolbox BSB is simply an alternative integration option for BricsCAD.
  3. Can I convert my Toolbox AC licenses to Toolbox BSB licenses?
    1. Yes, you can convert your Toolbox AC licenses to Toolbox BSB licenses if you choose to. This would involve switching to the version of Toolbox that includes BricsCAD instead of relying on a separate CAD license. If you're interested in making the switch, your Microvellum Account Manager can assist you.
  4. Why wasn’t there an earlier notice about the end of Toolbox OEM updates and the switch to BricsCAD?
      1. We understand this change may feel somewhat abrupt. We carefully considered the timing of this announcement to strike a balance between open communication and the work required to ensure a smooth transition. We held off on announcing the end of Toolbox OEM updates and the move to BricsCAD until everything was ready, such as the release date, transition plans, conversion tools, and support resources, so we could give you clear answers from the start.
      2. The July 21st date was tied to a release plan target already in motion. As features, tools, and support came together, the window for communication narrowed. We waited until we could provide complete information, but we recognize that made the notice feel shorter than ideal. Although additional updates to Toolbox OEM will not be released after July 21, your existing installations will continue to function as they do today and beyond, allowing you to continue working without disruption.
