CHANGE Command
CHANGE Command
Changes the properties of existing objects.
Specify Objects
If you select lines and other changeable objects in the same selection set, you get varying results depending on the object selection sequence. The easiest way to use CHANGE is to select only lines in a selection set or select only objects other than lines in a selection set.
Except for zero-thickness lines, the objects selected must be parallel to the current user coordinate system (UCS).
Change Point or Values
Changes the selected objects. The result depends on the type of objects you select.
Lines
Moves the endpoints of the selected lines that are closest to the change point to the new point, unless Ortho mode is on. If Ortho mode is on, the selected lines are modified so that they become parallel to either the X or the Y axis; their endpoints are not moved to the specified coordinate.
Circles
Changes the circle radius. If you selected more than one circle, the prompt is repeated for the next circle.
Text
Changes text location and other properties.
Specify New Text Insertion Point
Relocates the text.
Attribute Definitions
Changes the text and text properties of an attribute that is not part of a block.
Blocks
Changes the location or rotation of a block.
Specifying a new location relocates the block. Pressing Enter leaves the block in its original location.
Properties
Modifies properties of existing objects.
The Plotstyle option is displayed only when you are using named plot styles.
You can change several properties at a time. The Enter Property to Change prompt is redisplayed after each option is completed.
Color
Changes the color of the selected objects.
For example, to change a color to green, enter  green or  3. If you enter  bylayer, the object assumes the color of the layer on which it is located. If you enter  byblock, the object inherits the color of the block of which it is a component.
  1. True Color. Specifies a true color to be used for the selected object. The integer values range from 0 to 255 separated by commas.
  2. Color Book. Specifies a color from a loaded color book to be used for the selected object.
Elev
Changes the Z-axis elevation of 2D objects.
You can change the elevation of an object only if all its points have the same Z value.
Layer
Changes the layer of the selected objects.
Ltype
Changes the linetype of the selected objects.
If the new linetype is not loaded, the program tries to load it from the standard linetype library file  acad.lin for AutoCAD or  acadlt.lin for AutoCAD LT. If this procedure fails, use LINETYPE to load the linetype.
Ltscale
Changes the linetype scale factor of the selected objects.
Lweight
Changes the lineweight of the selected objects. Lineweight values are predefined values. If you enter a value that is not a predefined value, the closest predefined lineweight is assigned to the selected objects.
Thickness
Changes the Z-direction thickness of 2D objects.
Changing the thickness of a 3D polyline, dimension, or layout viewport object has no effect.
Transparency
Changes the transparency level of selected objects.
Set the transparency to ByLayer or ByBlock, or enter a value from 0 to 90.
Material
Changes the material of the selected objects if a material is attached.
Annotative
Changes the annotative property of the selected objects.
Powered by AutoCAD®
