DRAWORDER Command
DRAWORDER Command
Changes the draw order of images and other objects.
Several options are available that control the order in which overlapping objects are displayed. In addition to the DRAWORDER command, the TEXTTOFRONT command brings all text, dimensions, or leaders in a drawing in front of other objects, and the HATCHTOBACK command sends all hatch objects behind other objects.
By default, when you create new objects from several existing ones (for example, FILLET or PEDIT), the resulting objects assume the draw order of the object that you selected first.
Use the DRAWORDERCTL system variable to control the default display behavior overlapping objects.
Select Objects
Specifies the objects for which you want to change the draw order. For the Above and Under options, an additional prompt displays in which you selected the reference objects that the originally selected objects should be above or under.
Above Objects
Moves the selected object above the specified reference objects.
Under Objects
Moves the selected objects below the specified reference objects.
Front
Moves the selected objects to the top of the order of objects in the drawing.
Back
Moves the selected objects to the bottom of the order of objects in the drawing.
Powered by AutoCAD®
